Results 1 to 10 of 13
Thread: Advice on 16v head
    Oct 2005
    Nowra, NSW
    Advice on 16v head
    What sort of mods do i need to do to put a 16v head on my 1.8?
    Im trying to work out costs etc. How viable is it cost and performance wise?
    Would i be better off working my 8v head, bigger valves etc.
    whats the best choice?
    cheers.
    Golfwise Guest
    YEP stick to 8v
    or spend your money wisely and buy a complete 16v as they are different in that they have oil squirters and special pistons etc etc
    Oct 2005
    Nowra, NSW
    thanks 8v sounds the go then, i dont want to buy an entire new engine.
    Some porting and extractors should see it well, will have to start saving
    thanks again
    Sunny Coast - The QLD
    And if some porting and extractors are not enough then do a low boost turbo install. They are cheep and you could probably get away with it for well under $1000 if you already have injection.
    MK1 floG soon to have 16v 2L with cable change gbox - need a 16v turbo manifold
    "Fit the gearbox ya bum." Loon - best post ever!
    Camden, Sydney
    A port, some extractors and a cam should make your 1.8 fly.
    Jul 2005
    Yes and 20 vavles and 2 cams and a ko4 and 18lbs and a golf 1 and some brakes that most golfs dont have. Oh yes and some Chinese door handles.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Go the Chinese door handles!!!!!!
    Belgianwaffler Guest
    "What sort of mods do i need to do to put a 16v head on my 1.8?
    Would i be better off working my 8v head, bigger valves etc. "
    Hi Static1800,
    the cheaper option would be doing a port job on your head (8V) and an exhaust system to suit.
    you can get a MK3 exhaust manifold and a mk2 gti down pipe for betterflow.
    also don't forget the intake side as well.
    for the 8v head get it shaved (if you don't already have hi comp pistons).
    ...... the next one would be a complete and in good working order 16v; now the cost could vary from here on depending on whether you already have k-jetronic injection or digifant.... if the later then $$$ as you will have to make up an injector rail for your 16v.... either way the 16v will not work at its optimum and you well setup ported 8v will trash it no problem.
    the last option of comverting your 8v engine to 16v is costly... you will need the following -> 16v crank sprocket, 16v intermediate shaft/pump drive gear/ block off plate for where the dizzy was sitting, 16v head and cam gear, 16v oil pump (yes it's different), 16v pistons, 16v dizzy/cap/leads, 16v intake manifold, 16v water pipe the one that goes from the water pump to the head... and there are more little bits and pieces not to mention a different accelerator pedal cable..
    so there you go after all that look back at option 2 again and it's still won't drive as well as it should as the ignition and fuel is not setup for a 16v.
    Oct 2005
    Nowra, NSW
    Thanks for that 16v head seems hardly worth the effort. I found out this arvo that my engine is a 2H model from a 90-92 Cabriolet with the digifant injection.
    Im looking at getting some extractors next and nice sports exhaust with it and saving up for the head to get done.
Similar Threads
  1. 8v head build up
    By static1800 in forum Mk2 Golf & Jetta
    Last Post: 05-03-2007, 09:16 AM
  2. Cracked Head - help needed
    By sparkie in forum Diesels
    Last Post: 07-12-2006, 05:13 AM
  3. Head gaskets and rings
    By hiho in forum Diesels
    Last Post: 05-05-2006, 07:04 AM
  4. 16v engines for mk1.... (subject now)...head refitting
    By finemk1 in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 12-12-2005, 03:38 PM
