Results 1 to 10 of 14
Thread: adjustable cam gear???
    Jun 2006
    Exclamation adjustable cam gear???
    right...I sourced this autotech cam just recently,
    what im after now is an adjustable cam gear
    http://www.autotech.com/prod_engine_camgears.htm
    has anyone had any experience with these?? any available to buy maybe
    im after some feedback on these and on this autotech cam as well
    cheers
    Mar 2007
    Hinchinbrook
    Hi there.. yeh i had one on my MK1 years ago... I think i still have it at home? maybe?.. im pretty sure i didnt sell it... will have a look and let you know...
    But yeh they are good... allowing a few degrees advance or retard..depending on what your after.. torque down low or up higher in the rev range.....
    like i said will have a look 4 ya.. mario.
    Jun 2006
    thanks mate...
    did u use it wit an aftermarket cam or with stock
    at the moment, this lumpy cam that i got is really good for the top end, but im not much of a rever so shifting the power down lower would be great for me
    Aug 2006
    i'v seen on few peoples signatures with "muller adjustable cam"
    is that from mullers at lakemba?
    Mar 2007
    Hinchinbrook
    Quote Originally Posted by deemoIII View Post
    thanks mate...
    Hi there.. i used an aftermarket cam.. cant tell you the facts... Lift/duration as i cant remember.. but yeh, good power increase... I may still have the cam too.. i do remember seeing one a few weeks ago all wrapped up.. i take it you are after one for your MK1?.. are you going to run Twin side drafts or a single.... Single is better up to about 5500rpm, then you do see the diff with the twins above that too about 9000-9500rpm..
    i used twin side draft 40mm delorto's... i should still have these somewhere too but i cant find them....ARRRRHHHH!!!.
    mario
    Sep 2006
    Australia?
    Deemo how much was your cam, jkust curious, I am looking into one for the vr6 where abouts did you get it from?
    Jun 2006
    Quote Originally Posted by Mario View Post
    mario
    its a mk3, as u can see my power to weight is not the best, thats why i need that down low increse
    Quote Originally Posted by Mk3vr6 View Post
    swapt some parts with Matt, i would say $200 - 250 worth
    Aug 2006
    man this cam stuff sounds good, was looking at the link u posted deemo.. looks cheap less than $200.. i need sme low end torque too
    Sep 2006
    Australia?
    I'm looking at something like a 268 270 cam for the vr6. I got quoted 2200 bucks for a schrick one
    Oct 2005
    Nowra, NSW
    go Autotech steve, get sports valve springs and the cam gear while your at it to
