Results 1 to 3 of 3
Thread: ABF cold start
    Feb 2006
    Camberwell, Victoria
    ABF cold start
    Hey!
    When the engine is cold, it dies repeatedly after being started. It's annoying, but I can control it by holding the throttle open a little until it gets warm enough to control itself.
    Now, as far as I can tell, the idle stabilization valve will open a little more when cold, and gets the cue from the coolant temp sensor. When warm, it will go back to normal.
    Now, here's the deal...
    I unplugged the signal wire to the isv, and it didn't change anything.
    So i checked the voltage over the two signal wires, it read just under 1 volt when warm and idling normally.
    When I get a hand, i will check the voltage to see if it changes when i try another cold start...
    Therefore, can i assume there is a problem with the isv, or the ecu...given the loom is ok as there is voltage and complete circuit there...
    pics for clicks..
    Clean out the throttlebody really well with some carb cleaner and a rag. I'd also have a look at it with VAG-COM there maybe a problem somewhere else.
    Other things that come to mind are the water temp sensor that feeds the computer could ba giving out a duff value causing the computer to lose control.
    Does this only happen after being stood over night?
    With VAG-COM you can check that the throttle pot is changing smoothly from closed to full throttle.
    GAvin
    Peregian Beach
    Can you feel it vibrating? It should be buzzing or vibrating when it is working.
Similar Threads
  1. Passat Hard to Start when Hot.
    By auspassat in forum Passat (B4 & B5)
    Last Post: 12-03-2007, 11:13 PM
  2. Cold Air Intake (with MAF sensor)
    By midget in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 18-10-2006, 11:35 AM
  3. Car hard to start on cold startup
    By Golf Loon in forum Mk2 Golf & Jetta
    Last Post: 08-11-2005, 09:47 PM
