Give throttle body a clean and make sure none of your breather hoses are blocked or leaking . How many k's on this engine ?
I'm running a catch can, the whole intake is oil residual free!
But the catch can only vents from the block, as the valve cover does not breath.
However, I think i found the problem, there seems to be a vacuum leak around the fuel pressure regulator.
Is there a good way of maintaining a good seal for vacuum lines?
if you dont want it to move, put a light wipe of hi-temp silicon around the outlet and slide the hose onto it and clamp it lightly
Get some polypropylene lines - they stretch and seal a lot tighter
1976 Project Carbon Mk1 - Sold! |
2015 Lotus Exige Cup |
F80 M3 Family Wheels
- You may not post replies
- You may not edit your posts
Forum Rules
