Results 1 to 6 of 6
Thread: 9A Golf engine versus 2.0 FSI
    Maitland NSW
    Can someone familiar with the FSI engine tell me the differeneces.
    They appear to have the same bore and stroke, are they totally
    different or are the dimensions physically similar etc.
    Just curious, with the 9A engines getting on a bit, was thinking about
    using FSI engines in future.
    Jul 2005
    Melbourne, Williamstown
    Very different is all I can say, try doing a search on the "club gti uk" forum someone pulled an FSI engine appart and you can see the pistons and cylinder head are a very strange shape.
    mk2 GTi 16v
    Corrado G60
    May 2006
    byron bay area
    You would have an extra 10kw to start with, but I would say that it would be very challenging to do a converssion in the way of electrics & you would need to put in an extra engine mount
    Camden, Sydney
    You could probably use passat ADR engines, they come in Audis too.
    20V NA. They are a bit taller too.
    Or you could accept the taller block as necessary and run 2E 2L bottom ends from a Golf 3, they are cheap and reliable.
    Jul 2005
    Got a 2.0 FSI engine right here,buy it,fit it and tell us all how easy it is.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Maitland NSW
    Just wondering, IF we end up collaborating with VW australia,
    we might think about using/racing FSI engines. If they are taller by a
    significant margin thats a hassle because it raises the centre of gravity
    of the engines mass and hence the car.
    Not normally an issue in a road car but in an open wheeler it does.
    Had a look at "club gti uk" great site, couldnt find the comparison tho.........
