Results 1 to 9 of 9
Thread: 8v Stem Seal replacement- head on.
    Oakleigh VIC
    One with one without seal.
    Stem seals come with an installation aid to prevent damage to the seal as they're slid over the valve stem. (The blue thing!)
    A little bit of light machine oil (or engine oil) on the seal helps it slide into place too.
    The seal is pressed home ideally using a special tool but in this case I've used a 1/4" socket of just the right internal diameter to slip over the seal and drive it home by pressing on the seals metal collar. A couple of very light taps from a small hammer and you can tell it's home when you hear the hammer blow sound like you're tapping on metal.
    Spring and retainer back in, collet going back into place
    Let the spring back up.
    All tools available on e-bay
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Awesome write up Pete as usual
    A - Grade!
    Another thing to add is most of the time with these cyl. heads, the valve stem seals were out due to valve guide wear too.
    Another ol-skool trick if you don't have a air compressor or fittings etc is wind the engine down to BDC.
    Remove the spark plug
    Feed some ( a fair amount) twine etc into the spark plug hole obviously leaving a length hanging out so you don't have to fish the twine out through the spark plug hole!
    Then carefully & slowly wind the engine upto TDC in a clockwise direction till it stops/jams
    This is another way to hold the valves shut while removing the springs & not having the valves drop onto the pistons
    Oakleigh VIC
    Thanks Tim,
    Yeah I should have pointed out that replacing stem seals is usually only a stop gap effort as by the time they're worn out chances are the rest of the motor is too.
    I did check the guides by releasing the air pressure and wobbling them about, to be honest I wasn't too impressed with a couple of them but it's for a friend, going into a weekend car with a tight budget on the RWC. It'll see her through for probably a couple of years the way it is.
    Bit of an odd motor this one too, first solid lifter 1800 I've seen it's ex pommy import Mk1 carby cabrio.
    That's a neat trick with the string, I've seen a few air holds made by smashing the top off a spark and brazing an air fitting to it too.
    Pete
    7? MK1 Caddy
    12 Amarok
    Your right about the band aid fix though. But to put both your's & her mind at ease
    I replaced the valve stem seals only in my current stock GX with I fitted the engine to replace the angry one & its done nearly 40K since replacing them without fault.
    Only over the last few weeks has it had some overrun smoke, buts thats also from fitting the turbo as well & mostly when backing off from full high rpm/high speed power runs.
    So it should last a while!
    Perth. WA
    You need to make sure the spring seat ( metal ring) is still on the head before fitting the seals also, they usually DONT fit over the installed stem seal.
    great write up Pete.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Jun 2008
    Nice write up, nothing worse than dropping half a collet !
    1993 MK1 CAB ! Work in Progress........
    awesome write up as usual!!
    I have to do mine sometime soon
