DNA Tuning (Australia)
Results 1 to 8 of 8
Thread: 4 Pot Lightweight Caliper in OE size
    Feb 2007
    Brisvegas
    Hi mate, I can confirm that 4 pot calipers on 312mm rotors are brilliant mated with decent fluid, pads, lines and rotors. They just bite so hard and not just initially either. The harder you progressively push the pedal the harder and faster you will pull up. It's like you have to concentrate on how much pedal you use because the clamping force is so controllable but can easily be overdone. So make friends with your rear view mirror
    Not to mention the big unsprung weight difference between say the Porsche or Brembo calipers v's stock.
    Nov 2009
    Quote Originally Posted by VWindahouse View Post
    Cheers thanks for that...might be worthwhjile upgrade...what 4 pots are you running?
    The weight saving on these RB calipers alone make it worthwhile - just under 3 kg per side including mounting bolts, adapters and pads. That's abut half oem weight : )
    Volvo S60 RD T6
    Nov 2009
    Cheers Gav, you are knowledgeable in all things car!
    Geez I just had a quick look 750 pounds just for refurb ones!
    Vw Audi Tt Seat Skoda brembo brake calipers, pads,discs Brackets And Lines | eBay
    RB might be a good affordable option!
    Volvo S60 RD T6
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by thezoneR32 View Post
    That's why I bought new calipers, was not too impressed with the price of 8~10 year old refurbished calipers
    (On top of that, wait until you see the postage cost!)
    I have a link at home for a place in the UK that sells Brembo calipers for like 500 GBP
    May 2010
    Perth
    had LCR brembo's back in the day
    highly rate them!
    guy called DaveB (i think) on UK mk4 forums refurbs and resells them.
    Current: '04 Astra SRI Turbo - EDS IPF Flash, 3" TBE, Quaife LSD
    Previously: Bora 4mo, cams, coilovers, tune, exhaust, brembo's etc
