Hey mate Bosch do a drop in 4 bar reg for your OEM fuel rail. Only about $50 or so and 10 min DIY. I'm running one with no probs.
Hi,
I have got a polo gti 9n3, and am completing a few mods...ok more than just a few.
My question is that I need to get a new 4 bar FPR, and I am sure a lot of you have already done this, so what would you suggest..it would be great if you could give me some part numbers nad makes/ models..and even beter where I can get this from...appreciate you asistance.
With the 4 bar reg you will only see real benefit if you are going to run a bigger pump and injectors, some say better atomisation with the fuel rail having 1 bar more pressure.My opinion is the injectors will only spray the amount designed and for however long the ECU decides they must. Id be keen to hear more as ill be looking into similar mods with my 6N2 harpoon.
Jmac
Alba European
thanks vwindahouse...just btw do you have a part number, or did you just ask fire a 4 bar fpr for any 1.8 turbo vw
Sorry forgot that part, it's the same one for the MK4 Golf GTI
Volkswagen Golf IV 1.8T > Engine > Fuel > ES#1073 Bosch OEM 4.0 Bar Fuel Pressure Regulator - 0280160575SJ
And I know youv'e mentioned you're doing some major upgrades soon. Just wondering what you have in mindYou really won't need the reg unless you're adding more air flow and boost to the equation.
Thank you... am looking a tryng to get as much power out of the litte polo as possible whist still being a road carI love these little Polos, as I a sure you do. I have had polo's, since the first was released over a decade ago. So what I am doing is, remaping ECU (APR), sorting out intake (BC/carbonio), 3" down pipe ...debating about the exhaust, as I dont want to much noise, and the polo exhaust is not bad. New larger intercooler , FK highsport coilovers .......
and finally:
1. Puting in a "beter" turbo ---T4 (have not done this yet) , and ths is why I am sowly buying parts for the car to get it T4 ready (FPR,
3" MAF etc..).
2. Putting in bigger calipers and disks
Also keep on making the polo more pretty, beter mags, badges etc.....
If you are stuck the Passat BBG V6 runs a 4.0 bar reg standard if you are looking for one. Plenty V6 engines in the Euor wreckers these days
Jmac
Alba European
