No chance on the standard turbo. Sorry to burst your bubble.
hi guys!!
i'm new here and would appreciate all your tips and advised
i owned a 99 gti 1.8t and would like to know if i can up my hp more??
what mods do i need and how much will it cost?? (don't want a turbo upgrade)
currently i got a custom 2.5" turboback exhaust a short ram air intake and a stage 2 revo chip
don't know hp exactly but i'ts pretty fast!!
but sitting next to my friends WRX's my car is always a shadow to them if you know what i mean
they always teast me for owning a golf, but i love my car!!
so PLLLLZZZZZZ help me!!!
You're probably best to check out the Polo 9N3 subforum to see what the GTi guys can get out of this engine since it is the last car to use the old 1.8 turbo.
lol...start strippin the heavy stuff of ur car...
nah mate ring a turbo place and see if theres a mod they can do to ur little turbo..
look at things like the wheel of the turbo or modding the wastegate just little things that will help..
Wow! Thats sad![]()
anyways i got a 5000 budget, will this be enough if ever i upgrade my turbo?
Is there anything else i need for this upgrade? Will a ko4 do the job?
It all depends on what you are after. You can gain a little by maxing out the K03 but for any larger you'll need
Injectors
Intercooler
K04 or bigger
Clutch and LSD
Retune to suit injectors
Aftermarket boost controller
You could do a K04 mod fairly cheaply if you get the kit off an S3 and dont' bother with an FMIC but its still not a modded WRX killer they are AWD afterall
Meh go crazy with a GT series turbo and kick some butt
is there a place here in sydney where i can get this s3 kit for my car?
i'm kinda new with this modding stuff
and that gt series is that expensive?
VAG just to clear a few things up for you.
Apologies if you know this but the S3 is an Audi, which comes fitted with a K04 turbo, to support this it is fitted with larger injectors, a higher pressure fuel pump and a bigger MAF(air flow meter).
Finding a scrap S3 to get these bits from in Australia wouldn't be that easy.
Also, the K04 on an S3 has a different outlet to the down pipe when compared to your Golf, due to the 4wd. This would mean getting a new downpipe as well. There are off the shelf conversion downpipes available on the net.
For $5k though you could do the conversion and get your 250hp but you will still be following your mates in the Subarus.
@Mark, why the aftermarket boost controller?? Just curious.
....**** 5ki would still be lookin at wat i said....a bigger G size wheel in the turbo....
IHI turbos do them...
Seb had an S3 that he was doing a turbo upgrade to something bigger a while back and I know the owner was going to off load the old stuff. I thought about putting it on the A3 but now the R has turned up I've run out of time. It might not be available though
What I meant but didn't explain properly with the Boost controller is that with his being a 99 it will be an ME3.8.x without a MAP sensor so boost control is effectively back calculated calulated from the MAF table. You run the bigger S3 MAF sensor housing for sure but still boost control becomes an issue at high load and its never perfect most likely because it can't do the calulations and have the wastegate in the perfect position in time. The simple solution is to put in a bleed valve just at the point where you would like the boost to be capped this way its never going to exceed it, the ECU still manages boost below this point though. If your chasing lower targets then the worry about boost control not being as effective isn't there. So not an EBC as I said last night, just a bleed as a safeguard. They are pretty cheap and work well.
Oh if he had an ME7 ECU as used in the later cars you don't need anything at all of course
