Results 11 to 20 of 32
Thread: 16v engines for mk1.... (subject now)...head refitting
    TassieGTi Guest
    Inlet manifold
    1.8 Inlets are the smaller ones whether left or right, whereas the 9a 2.0 is the bigger one.
    Big is not always better and light flywheels are awful on road cars driving around the street.
    black betty Guest
    early kr (1.8 ) from golfs in the late 80's had 50mm inlets
    in the uk i have owned kr 1.8 with 50mm inlets and a 1991 passat 1.8 with 40mm inlets
    the 50mm inlet car had less torque but revved harder and had much more power at the tope end
    hope that helps
    Golfwise Guest
    Torque
    Sometimes we forget that other places are flat whereas we have lots of hills in Tassie even our local race track has a whopper so torque to us is good.
    Re: Torque
    Quote Originally Posted by Golfwise
    i think torque is good fullstop!!!! you dont wanna always rev an engine to the stratosphere to reach its full potential.
    PERTH
    measured mine up and there the 40mm ones with TB on the left side this has got me thinking in i want the 50mm one now but you say the 9a motors had the intake on the right side, do 50mm left side intake manifolds exsist?
    so using a 40mm intake and a lightweight crank pully and windage tray could result in the same top end revs as the 50mm thus keepin the low down torque of a 40mm?
    the golf is not dead.
    black betty Guest
    you can get 40mm and 50 mm inlets for both sides
    throttle body mount on right side are generally found on scirroco 16v's in europe and us
    most other models i.e. corrado, golf, ibiza and passat have throttle body mount on left hand side (as you face the engine from front of car)
    scirroco inlets are usually more expensive (esp 50mm ones) as are used in 16v g60 conversions as well as mk 1 16v conversions
    Camden, Sydney
    Quote Originally Posted by black betty
    early kr (1.8 ) in the uk i have owned kr 1.8 with 50mm inlets and a 1991 passat 1.8 with 40mm inlets
    the 50mm inlet car had less torque but revved harder and had much more power at the top end
    So If I have a 2L with the 50mm inlet and a lightened flywheel, will that make it have more go from the offset?
    I have a feeling its going to be largely psychological. Any 16v in a Mk1 will be a lot a fun and feel even faster than it is.
    black betty Guest
    i d go the 50mm ones
    this can be a controversial area though
    do a search for this topic on clubgti uk forums
    a guy known as GVK has done the transfer on a 2.0 9a from 40 to 50mm
    he always has it rolling roaded and results will be up there somewhere
    good luck
    VanKronenburg Guest
    Re: Inlet manifold
    Quote Originally Posted by TassieGTi
    The later KR and SEAT spec 1.8 16v Digi 2 ADL motors also came with a 50mm intake, so it wasn't just the 2.0s
    VanKronenburg Guest
    Also, you don't need the 'Rocco intake for plug lead clearance. I used a Saab 900 16v 90deg exit dizzy cap instead of the stocker and it cures any problems. There are a few others that fit but the Saab one is the only one I've tried personally.
    10lb flywheel is a good compromise with an 02A, as is an 8lb with the 020.
Similar Threads
  1. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  2. Head gaskets and rings
    By hiho in forum Diesels
    Last Post: 05-05-2006, 07:04 AM
