Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: 1.8T conversion information
  1. #21
    Perth. WA
    Quote Originally Posted by MK2 GTI
    Is there any site on getting the 1.8T motor going without the plug and play kit. Because i've been told it's now illegal to get a car registered with an aftermarket ecu. Im talking about the ECU that comes with the 1.8T and not the ECU in my car at the moment.
    Go have a look at Kirsten's web site, this will give you an idea of what is really involved to do a conversion correctly. Take particular note to the wiring sections...:roll:
    http://www.funksoulkitty.org/
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  2. #22
    I think you may need to read below.
    Up in the UK custom-code.co.uk can deafeat the immobiliser just this kind of install. You can run a complete factory set up without having to use the clocks and keyreader etc.
    The cost in the UK is £200 on top of what ever remap you require. All plus VAT here. It is not available on it's own unfortunately, but why would you fit the engine and not turn it up to 11
    Obviously you have started thinking thats loads. However once you go stand alone and spend a packet on mapping and rolling road time it makes sense.
    The other point you have is the distance to the UK. This should not be a issue from next month.
    I am moving to Adelaide and have already signed up as a Custom-Code agent. There will be some ECUs that I don't have the ability to flash, early 110 TDi for example. These require replacement chips installing in most cases.
    Anything more modern than this can generally be flashed through the OBD port while in the car or by powering up the ECU on the bench, this applies to DBW and non-BDW as well as the PDs. This gives me the ability to do the remaps by post if required.
    Clearly any existing faults would have to be cleared up prior to the flash taking place. Even in the short time I have been doing this, most cars unless brand new, require some attention on top of the remap to work 100%. Usual suspects being MAFs, DVs and boost leaks etc. Thankfully, VAG-COM is a great tool for hunting these snags out.
    If any of the above information is of interest to you guys downunder don't hesitate to contact me through the forum. I will be setting up a website etc when I land.
    Thanks
Similar Threads
  1. Mk1 Commodore Caliper, 278mm Magna rotor conversion
    By golfnutracing in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 06-06-2011, 04:23 PM
  2. Brake conversion
    By rayray086 in forum Mk3 Golf & Vento
    Last Post: 28-11-2006, 11:32 PM
  3. mk1 vr6 conversion?
    By glf-mk1 in forum Mk1 Golf
    Last Post: 08-02-2006, 01:52 AM
