DNA Tuning (Australia)
Results 1 to 9 of 9
Thread: 1.8T - Catch can and PCV info
    Jan 2009
    blankedy
    I'm looking into options for the PCV system and Catch cans.
    My main query is around the operation of the TIP connection in the system. Is the vacuum in the TIP under boost used to help open the PCV system (valve)?
    If not, why do people route it here and not just let it drop somehwere else?
    There seems to be a few different Catch can configs, but many concerns about how much they collect vs. blocking required flow.
    Has anyone routed from the valve to ground / atmosphere? Would this work?
    This subject needs some serious research and responses fro mthose who know...... well put noone! cheers Al
    May 2010
    braidwood n.s.w
    hi mate.my advice is you dont want to pressurize your sump.oil vapur getting sucked into your is not go for the turbo charger.have a look at you crank case oil vapur system and see.if its getting sucked into the turbo dissconect and put you catch can in and nothing else.let me know how you go.
    Jan 2009
    blankedy
    Thanks mate.
    I'm not ready to do anything about this yet, but it seems like there are a number of different designs and i don't have a good understanding about how the system works.
    If the vapour coming from the line is nothing but waste gass and fumes, why would it be routed back into the intake system?
    It makes sense that the check valve (hockey puck) is using the vacuum created by spooling to draw out some of these fumes, but the rest is still a mystery...
    If it is waste, why would they not make a reservoir standard and have it emptied at service intervals? Odd.
    more Vortex reading...
    sydney
    Thanks mate.
    its all for emissions, the gas return back into the inlet and are burnt through the stroke, the hockey puck is in place to remove oil particles, but as you can imagine you still get heaps of oil being pushed(especially in boosted applications) back into the inlet, and through your cooler and so on
    i emptied mine not long ago and the result was amazing, cant imagine what all that **** going into clean inlet air wold be benificial
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    Jan 2009
    blankedy
    The hockey puck does not filter, i've seen a cross section of a dissected one, its just a flow valve sorta thing (as I can not clearly describe, better I don't try).
    ok, i'll be less lazy and give you the link
    sydney
    not filters as such but houses the oil, ie liquid stays at the bottom of the round area gas under pressure activates the spring and enters the inlet but as under boost the oil ends up more pressurized and gets pushed into the inlet
    Jan 2009
    blankedy
    From the thread I've linked, that is not correct.
    Have a read mate, its quite interesting.
    sydney
    learn something new everyday
    all i can say is makes me happy to know all the crap i just emptied out of mine wasnt making its way into the inlet
