Originally Posted by
sambb
I'm pretty keen to convert my non-VVT head over to VVT operation.
My aim of this is to use intake advance throughout the rev range to boost off boost running and spool up.
Yes I'm aware its an ON/OFF system (not infinitely adjustable) but that didn't stop Audi using it this way
and I want to do the same.
Now looking into this and reading that the VVT system moves
the cam a total of 20° crank degrees - so 10° cam degrees.
ie 20° crank degrees advanced from its set point at cold start (and between 2000-4800 Rpm in Audi's)
and then retards back to set point (displayed as 0° degrees) for the top end.
You can see this in blocks 091 and 094 in VCDS - actively in an Audi.
