They're not a perfect seal, to be honest.
Maybe just give it a good clean, and monitor how bad it is?
Hey guys,
Loving my Wolf. Has anyone else noticed this? Lots of oil around the filler cap. I cleaned it off and it reappeared within a few thousand kms. No codes on VCDS.
Suggestions?
Mk 7 R Wagon Wolfsburg. APR Stage 1. Removable towbar.
Hmm, I did, and as mentioned, it was back in a few thousand km. I'm just nervous I'm getting piston ring blow by.
car has warranty why you care
"Forced induction" sounds like some sort of sexual assault.
i drive a Golf 7R tuned by APR + exoticars
Check to see if the rubber seal on the bottom of the oil cap is still there. Maybe look for a thicker o-ring for a better seal?. Piston ring blow by would result in your sump being pressurised and your dip stick popping out. What is a few thousand kms? 2000, 10000? If you are concerned about the blow by, maybe get a compression test to put your mind at ease.
