Results 1 to 5 of 5
Thread: Wolfsburg R Oily oil filler cap. PCV failure? Crummy seal?
    Mar 2014
    Newcastle, NSW
    Hey guys,
    Loving my Wolf. Has anyone else noticed this? Lots of oil around the filler cap. I cleaned it off and it reappeared within a few thousand kms. No codes on VCDS.
    Suggestions?
    Mk 7 R Wagon Wolfsburg. APR Stage 1. Removable towbar.
    Dec 2008
    Sydney/Canberra
    They're not a perfect seal, to be honest.
    Maybe just give it a good clean, and monitor how bad it is?
    Mar 2014
    Newcastle, NSW
    Hmm, I did, and as mentioned, it was back in a few thousand km. I'm just nervous I'm getting piston ring blow by.
    Oct 2010
    NW Sydney
    car has warranty why you care
    "Forced induction" sounds like some sort of sexual assault.
    i drive a Golf 7R tuned by APR + exoticars
    May 2016
    Check to see if the rubber seal on the bottom of the oil cap is still there. Maybe look for a thicker o-ring for a better seal?. Piston ring blow by would result in your sump being pressurised and your dip stick popping out. What is a few thousand kms? 2000, 10000? If you are concerned about the blow by, maybe get a compression test to put your mind at ease.
