Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 110
Thread: Windscreen Wiper Issues
  1. #51
    Jan 2014
    Burleigh Waters, QLD
    More info please
    Quote Originally Posted by Snail Style View Post
    There is a technical bulletin for this issue. The original bosch blades need to be replaced by Federal Mogul blades to rectify the issue.
    Do you have a ref number and/or date for this technical bulletin please?
    Also, does the bulletin apply to all Mk7 Golfs? Or will recently manufactured cars come with wipers that don't have the problem?
  2. #52
    Jul 2012
    Sinagra, Western Australia
    Can't be sure. It effects all Golf 7's fitted with Bosch blades. I'll see if I can get hold of it tomorrow.
  3. #53
    Jun 2013
    That would be great if you could, thanks!
  4. #54
    Apr 2014
    Hampton East, VIC
    Not having any issues with my wagon picked up 2 weeks ago. I mentioned it to the dealer prior to delivery and he said they always replace the wiper blades anyway....
  5. #55
    Aug 2013
    Melbourne, Vic
    Quote Originally Posted by flight View Post
    Took my Golf in for the 45D4 update and got the dealer to look at the wipers. I Originally had the Valeo wiper blades which they replaced with Bosch OEM blades in February. I was still experiencing the streak in the drivers lines of sight, however, it wasn't as bad as the Valeo ones. The dealer tried telling me that I should use some kind of wax/compound on the windscreen and to clean the wiper blades every couple of weeks - when I told them this wasn't acceptable and that there is probably a defect with the blade design, they blatantly said there was nothing they could do for me and basically suck it up.
    As I didn't find this acceptable, I decided to take a gamble and order the Bosch wiper blades from the Bosch store/website as others have reportedly done. They arrived today and I fitted them straight away. I was skeptical.... But much to my amazement, they bloody work!!!!
    No more smearing & quiet operation. To think I have been putting up with this problem for 6 months and all it took was me to order the Bosch Independent aftermarket part! VW really need to get their sh*t sorted!
    So if you are experiencing the wiper smear like I was, I strongly recommend the Bosch Aerotwin A864S blades!
  6. #56
    AU
    I'm experiencing some "shuddering" with the rear wipers when it's on the way down, tried cleaning the glass and everything but no dice.
    Anyone knows if I can just order another set online?
    Mk 7 GTI PP
  7. #57
    Nov 2013
    AUS
    Quote Originally Posted by DP Vic View Post
    Happy to hear they're working well. Keep us updated with your progress after a few months, that is the real test as most wipers work pretty well from new
  8. #58
    Mar 2014
    Perth
    Quote Originally Posted by n0d3 View Post
    I had this issue for the first 2 weeks after delivery of my vehicle. Took it for a cruise and my girlfriend went nuts inside the car (it was a rainy day). Now, after 2 weeks of non stop rain I can safely say it's finally gone.
    Sent from my SM-G900I using Tapatalk
    GTI PP Mk7
    My grandma used to say...
  9. #59
    AU
    Quote Originally Posted by wasabiz View Post
    Thanks for the heads up! Will see how it goes.
    Mk 7 GTI PP
  10. #60
    Apr 2014
    BRAND NEW Golf MK7 Wiper issues on the first day of driving - ALL NEW OWNER MUST READ
    Hi All
    For those who is going to pickup the Brand new Golf, I would highly recommended you to check your WIPER especially on the driver side. I pickup my car on on 31-May2014 and on 1-June-2014 (less than 1 day) I discovered the wiper does not work smoothly. I notices a lot of owners having the same issues on internet and because I discovered this the second day I pickup the car, the sales person willing to fix it and replace it with a replacement model of blade for us. FREE of CHARGE. The service manager advise this is a known issues of VW Golf MK7 but they will not proactively replace the problem blade. He also mention if owner report it after 1000KM, they will treat it as wear and worn, the owner will have to pay for replacement. I am lucky enough to discover this. When you pickup your BRAND NEW GOLF MK7, Please use the wind screen liquid on and off for 5 minutes and you should able to discover the issues.
    Good luck to all new GOLF MK7 owner.
