Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 73
Thread: Why is 504 / 507 oil so readily available when it should not be used here?
    Jul 2013
    Tas
    From what I understand, VW in Aus use flexible service (long life) which means that the ECU and algorithms determine when to inform you that service is due.
    So you use 508 or 504 for a petrol engine per that table. Alternatively you can use 504 for a petrol engine if in Australia.
    So use 504 for a petrol engine in Australia.
    Or don't. It's up to you.
    You missed the point a) in the heading of the alternative oil column.
    Australia use fixed services. QI4 in the first page of the service book. See the middle column for fixed services. It says 502. The alternative says 504 but there is a point a) at the top of that column. The matching footnote for point a) reads:
    "Alternative engine oil specifications may only be used in fixed services QI1, QI2, QI3, QI4 and QI7, and only when fuel of a quality compliant with EN 228, or fuel of an equivalent quality, is available in the particular country"
    EN 228 specifies 10ppm sulphur. Australian fuel does not even come close to complying with this. Australian sulphur limit for 95 and 98 RON is 50ppm, 5x that of EN 228.
    Pacific Paradise QLD
    Take it up with VW, not us We do what it says in our service book and my car says use 504/507 so thats what it gets
    Jul 2013
    Tas
    I'd be interested to see what's in your book. The Golf and Polo have the page like mine. I'm just interested.
    Young NSW
    We have a brand new 2020 Alltrack 132TSI. There is nowhere in the supplied manual/supplement or service schedule that mentions the oil standard ie 504/507. It does mention that for emergency top ups 502.00 can be used (max .5l) VW recommends Castrol oil in the manual. Castrol recommends EDGE 5W-30 LL. VW standard 504 00/ 507 00. Thats what is going in the car when we have the oil/filter changed at 1500k's as an extra service. The thought of leaving the factory fill oil/filter in until the first scheduled service at 15,000k's is a little beyond my mechanical sympathy.
    VW number 8 = 2020 Golf Alltrack Premium/Indium Grey Metallic/Leather seats with extra fruit. (Gone)
    VW number 9 = 2023 Tiguan Elegance 162 TSI White with Sound and Vision package
    Dec 2008
    Sydney/Canberra
    All diesels are spec'd with 504/507 since 2004 in Australia, with the exception of a couple of specific engines.
    Bear in mind, the book is not specific the Australian market.
    Worth noting that 504/507 oils are rated for 30,000km drain intervals, however the service intervals for Australia (besides the Crafter), are 15,000kms, or 12 months.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Quote Originally Posted by bradsm87 View Post
    Send me your VIN via PM I'll check the PR code for your service regime.
    If it's fixed interval then you might need to speak to your service representative.
    If it's long life then the logic that's been pointed out applies.
    Jul 2013
    Tas
    It's QI4 fixed 15k interval. Manual says to use 502. I've sent an enquiry to VW Australia asking what the go is and if in fact the recommendation is now to use 504, if they can supply me with a supplement for the owner's manual.
    Sounds like a good course of action.
    I don't know anything about what service regimes apply to what vehicles. All I can do is check the PR codes and report what the factory specification is.
    Jul 2013
    Tas
    Thanks mate. I'll flick you a PM with my VIN tomorrow too.
    Here you are Read the right hand column which refers to the second pic
    Who are we to argue with VW if they say that
    Attached Thumbnails Attached Thumbnails Why is 504 / 507 oil so readily available when it should not be used here?-vw-engine-oil-recommendations-jpg   Why is 504 / 507 oil so readily available when it should not be used here?-under-bonnet-sticker-jpg
