Well my Tiguan has a sticker under the bonnet with 504/507 on it so thats what it will get. Im not a chemist so if thats what they want I will use it as if i use something else and have troubles i could be deep in smelly brown stuff
The owner's manual says to only use 504 00 / 507 00 oil in markets where the fuel meets EN 228 standards (10ppm sulphur), otherwise to use 502 00 oil instead. Australian 95 and 98 RON fuel can be up to 50ppm sulphur and does not meet EN 228 fuel standards, therefore 502 00 oil should be used (according to the owner's manual). This is why I never trust oil vendor's product guides (which in this case all seem to recommend 504 / 507 oils) or mechanics that just use oil vendor's product guides.
Am I missing something? Should I be going against VW's recommendation like nearly every oil vendor's product guide recommends?
100% stick to 504/507. If you have any engine related issues under warranty, you probably won't be covered.
It's not theorising. It's right there in the owner's manual. The owner's manual says to use 502 and only lists 504 as an alternative IF the country's fuel standards meet EN 228. BMW, MB and others do the same thing. BMW specify LL-04 in Europe where they have low sulphur fuel but LL-01 here because of our ****ty fuel for example.
Attachment 50752
Here is a pic of the oil page in the owner's manual.
From what I understand, VW in Aus use flexible service (long life) which means that the ECU and algorithms determine when to inform you that service is due.
So you use 508 or 504 for a petrol engine per that table. Alternatively you can use 504 for a petrol engine if in Australia.
So use 504 for a petrol engine in Australia.
Or don't. It's up to you.
