Page 1 of 8 123 ... LastLast
Results 1 to 10 of 73
Thread: Why is 504 / 507 oil so readily available when it should not be used here?
    Jul 2013
    Tas
    The owner's manual says to only use 504 00 / 507 00 oil in markets where the fuel meets EN 228 standards (10ppm sulphur), otherwise to use 502 00 oil instead. Australian 95 and 98 RON fuel can be up to 50ppm sulphur and does not meet EN 228 fuel standards, therefore 502 00 oil should be used (according to the owner's manual). This is why I never trust oil vendor's product guides (which in this case all seem to recommend 504 / 507 oils) or mechanics that just use oil vendor's product guides.
    Am I missing something? Should I be going against VW's recommendation like nearly every oil vendor's product guide recommends?
    Pacific Paradise QLD
    Well my Tiguan has a sticker under the bonnet with 504/507 on it so thats what it will get. Im not a chemist so if thats what they want I will use it as if i use something else and have troubles i could be deep in smelly brown stuff
    Jul 2013
    Tas
    I've got a feeling VW Australia have differed to what the owner's manual says. I just wish they would publish it somewhere properly and issue a supplement to the owner's manual.
    What engine is in yours?
    Dec 2008
    Sydney/Canberra
    100% stick to 504/507. If you have any engine related issues under warranty, you probably won't be covered.
    Quote Originally Posted by bradsm87 View Post
    Same as in my sig A 162 TSI
    Quote Originally Posted by Umai Naa!! View Post
    Yep a bit silly to theorize your way into problems. Just put in it what they say Mine have run on Penrite Enviro + for 10 year with no problems.. I supply it myself at services.
    Jul 2013
    Tas
    That makes no sense because the owner's manual says only use 502 if your country's fuel does not meet EN 228 fuel standards which Australia's fuel does not.
    Jul 2013
    Tas
    It's not theorising. It's right there in the owner's manual. The owner's manual says to use 502 and only lists 504 as an alternative IF the country's fuel standards meet EN 228. BMW, MB and others do the same thing. BMW specify LL-04 in Europe where they have low sulphur fuel but LL-01 here because of our ****ty fuel for example.
    Jul 2013
    Tas
    Attachment 50752
    Here is a pic of the oil page in the owner's manual.Why is 504 / 507 oil so readily available when it should not be used here?-oils-jpg
    From what I understand, VW in Aus use flexible service (long life) which means that the ECU and algorithms determine when to inform you that service is due.
    So you use 508 or 504 for a petrol engine per that table. Alternatively you can use 504 for a petrol engine if in Australia.
    So use 504 for a petrol engine in Australia.
    Or don't. It's up to you.
