Why is 504 / 507 oil so readily available when it should not be used here?
The owner's manual says to only use 504 00 / 507 00 oil in markets where the fuel meets EN 228 standards (10ppm sulphur), otherwise to use 502 00 oil instead. Australian 95 and 98 RON fuel can be up to 50ppm sulphur and does not meet EN 228 fuel standards, therefore 502 00 oil should be used (according to the owner's manual). This is why I never trust oil vendor's product guides (which in this case all seem to recommend 504 / 507 oils) or mechanics that just use oil vendor's product guides.
Am I missing something? Should I be going against VW's recommendation like nearly every oil vendor's product guide recommends?
- You may not post replies
- You may not edit your posts
Forum Rules
