Originally Posted by
AdamD
Sounds like you've got a haldex unit failure, and your car is effectively running in FWD mode. It's happened to a few local S3 owners as well. There are often no fault codes thrown, but in your case obviously there was one.
Get it down to your dealer and they should organise a replacement haldex under warranty.
Adam- good call! But it looks like that beast was being fairly aggressively driven in the video and the DTC in DKC's post has a fault frequency of 1. Just as a suggestion and before seeking a warranty claim - perhaps an easy try would be to see if the DTC can be cleared - If the error message doesn't re-appear on a subsequent scan, then it's probably a gremlin and worth trying to replicate (to confirm a latent problem with the haldex unit). Most likely, this is exactly what the dealer will do.
If the error message can't be cleared, then I agree that a trip to the dealer is worthwhile.
PS: I wouldn't worry that clearing the DTC will somehow reduce the chances of a later warranty claim because DKC always has the autoscan as proof of the original problem - and because dealers are well known for being fair (not) in such instances!
