![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
baloobb
Have you found a solution for this fault? I am getting the same one
I'm always puzzled when folk allege that they have the same fault as someone else -because a fault has so many different aspects that it's difficult to have two unconnected error-messages with exactly the same characteristics!
hmm......this ain't a particularly difficult error-message to diagnose - clearly as I said in my response to OP, the problem is almost certainty with the internal fan inside the 5F module (which is the MIB - the black box inside the glove-box).
This is where the fan is located in the MIB:
![What is MY16 TDI Fault Code - "Cooling fan for housing" ?-asf-png](https://www.vwwatercooled.com.au/forums/attachments/f197/56301d1739272939t-what-my16-tdi-fault-code-cooling-fan-housing-asf-png)
So, to pursue discussion further - you need to provide more words:
- what part of OP's fault is the same - is your fault status intermittent, or static?
- What diagnostic device are you using- post up a copy of the error-message?
- Have you tried testing the operation of the internal fan with your diagnostic device?
- If the internal fan needs replacing - will you do this yourself, or do you intend to throw money at a professional?
