@DV52
Don, I suspect VW are going down the lines like the RNS510 with their MIB1 maps and stopped support for our region to only include this with the ROW maps. Hence the larger map data not able to fit onto the 8GB OEM SD card. Unfortunate as the MIB1 does not support carplay/android auto for other maps.
The MIB2 maps show a different file structure so they are not backward compatible with MIB1.
Options I can see -
1. Try and find a larger VW SD card on open market place sites. This may work but be aware as the MIB1 SD card appears different to the MIB2 supported SD card. I am seeing V2 cards (5G0 919 866G) supporting MIB1 up to 03/11/2014 but this is only 8GB. 3G0 919 866S is a V4 16GB card supporting vehicles up to 07/11/2016 but may be for MIB2 only.
2. Flash your unit. Not recommending this as there is not enough evidence out there supporting this as successful.
3. Take up the issue with VW (both through the dealership service area and VW head office) to provide a solution to update maps beyond 2018. Mapping data should be supported for a minimum 10 years from when first introduced. So if VW play the 3 x monkeys than maybe talking to your local consumer affairs office is another step.
4. Time for an upgrade of the head unit.
Flipper Dog
Now - T-Roc R, Audi Q5
