Results 1 to 10 of 18
Thread: VW Golf Highline Mk7.5 - DUAL LED Daytime Driving Lights???
    Aug 2018
    Hi guys,
    First time VW owner here.
    Got my Golf Highline Mk7.5 a couple of months ago and I've just noticed only the outer LED DRL/Signal works. The other (inner) LED are not working at all. Is it a fault? or they are disabled on Golf Highline? Can someone confirm? Thanks.
    Apr 2017
    belgrave victoria
    The double drl are only enabled on the golf gti,R and alltrack premium models
    I think you can enable through obd11
    I have the double drl on mine and its very cool the single drl looks lame in comparison
    Aug 2018
    Thanks Kachingg.
    Is yours a Golf Highline? Just wondering whether the inner LEDs are "dummy"? or actual LEDs which just need to be enabled?
    Can I get them enabled by service dealer? I don't have OBD11.
    Has anyone enabled dual DRL on their golf?
    Quote Originally Posted by Kachingg View Post
    Apr 2017
    belgrave victoria
    I have a golf alltrack premium which means i have the double drl as stock
    I think it,s just a matter of coding for you to have double drl but don't quote me as i have not done it myself
    Check out the vcd's tweaks thread and post a question there lot's of knowledgeable folks there who could help you out
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    May 2017
    I have been advised that the inner drl is totally non functional and cannot be switched on by any means. apparently there are no leds even in the strip. VAG decided it was a point of difference be
    tween the highline and the GTI/R
    Aug 2018
    Thanks mate!
    Aug 2018
    That's my suspicion. Thanks for confirming. Might get a Carista OBD2 to play around.
    Cheers guys.
    Quote Originally Posted by Rufus1000 View Post
    May 2017
    I had all my codes looked at when I got the car and got traffic enabled etc there was nothing listed for inner drl activation on the highline. they are different light units apparently.
    Nov 2008
    Bankstown
    Hi to All,
    Rufus1000, I have purchased the 2019 golf gti, again inner drl not working. Dealership is near unresponsive. I can understand the high line not having the drl, but the gti is a concern.
    Any thoughts if the centre drl was disabled on the 2019 gig.
    Regards
    John
    May 2019
    Quote Originally Posted by johnvw View Post
    Hi to All,
    Regards
    John
    I just picked up my MY19 GTI with all the options and the inner DRL does not turn on. Not sure how to get it working.
