Results 1 to 10 of 10
Thread: VW Golf 7 Clubsport S rear muffler
    Dec 2017
    Gold Coast, QLD
    Question VW Golf 7 Clubsport S rear muffler
    I’d like to buy one of these for my 7.5 GTI.
    https://cars245.com/en/item/audi-vol...rear-silencer/
    My questions are, is the diameter of the Clubsport S muffler compatible with the 7.5 GTI? Also, is it reasonable simple for the original muffler to be unbolted/unclamped or does it need to be cut from the exhaust system.
    Apologies if if this has been covered before. Thanks in advance.
    Maribyrnong, Victoria
    Hi I got one of these fitted today to my GTI MK7 PP 2015 you need a special joiner clamp as well. It costs around 660 AUD to buy one in AUS I would buy it here not from overseas as the shippings is prohibitive. I will probably get the resonator as well. As if will fit your 7.5 I don't see why not.... I may get the resonator down the track as well. Part nos are 5G6253609DD and 1K0253141AA .
    660 plus the price of the clamp BTW
    Dec 2017
    Gold Coast, QLD
    Hi peekay. Apparently the 7.5 rear valence openings are a different width. So I think I’m out of luck. ;(
    Cant you just get the tips modified to fit? They are just Tips?
    Feb 2018
    Fulham SA
    Quote Originally Posted by peekay34 View Post
    Where in Australia did you get yours? Does the original pipe need to be cut or is it just a clamp undo and do up job?
    I got mine from a VW Dealer its a cut and then use 1K0253141AA Clamp with the muffler. Easy by an exhaust shop. On the existing pipe there is a cut mark exactly where you should cut. The exhaust shop I went to new exactly where it was. Took them like 25 mins to do .
    Jul 2010
    Clayton, VIC
    Hi All,
    What is the difference between the VW Golf 7 Clubsport S rear muffler and the standard 7.5 GTI muffler?
    Thanks
    Feb 2018
    Fulham SA
    cheers
    YouTube video of exhaust differences and YouTube
