Results 1 to 10 of 11
Thread: VW Golf 2.0TDI 2015 - lights questions
    Jun 2021
    Bulgaria
    Hello guys,
    I have VW Golf 7 2.0tdi with bi-xenon headlights and auto function on my lever.
    I want to know, is there any option, when the car is running on sunny day and my DRL's are ON, rear lights are ON too, but i want to be only from DRL's ON ?
    When its sunny day DRL's front/rear and interior lights are ON. I want on sunny day DRL's to be ON only on front and when the night come, to switch the lights in interior, back lights and headlights ON.
    Is there any codding for this ? I already have VCDS.
    Also, CH/LH function doesn't work on me.. I don't know the codding in my centr.elect 9. Can someone help me with tips and codes to do it ?
    Thank you.
    @confusedGolf: Hi.
    Not quite sure that I understand your question - but it sounds like your car has Scandinavian DRL activated. If I'm correct, check the BCM (@ address hex09) - look for the adaptation channel:
    • ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht
    If it's currently set to active, change to not active
    Jun 2021
    Bulgaria
    @confusedGolf: Hi.
    Dear Don, when I change this codding, my lights at day shut down(everything like drl,tail lights and interior).
    Is there an option to start only front drl now to run ?
    NOTE: The car was equipped with Humidity sensor only with no auto button.
    After retrofit done in Italy, the car have RLHS with auto button.
    If this info is useful ..
    Some pictures of my Ch9 codding:
    VW Golf 2.0TDI 2015 - lights questions-untitled-jpgVW Golf 2.0TDI 2015 - lights questions-untitled1-jpg
    hmm..... OK - sounds odd Rather than starting a dance of successive guesses -probably better if you create a BCM adaptation channel map. Load the file on a third-party hosting web-site and include a link in a new post here
    Set-up the admap dialogue box like this:
    Jun 2021
    Bulgaria
    Alright, Don
    I will do it after 5 hours, when i back to home and attach the cable to the car.
    Done - the map on ch 9
    Download - TransferNow
    Jun 2021
    Bulgaria
    Don, I found another issue with my electronics with multimedia controlling lights - when i push instruments light to 0 from the multimedia, they do nothing .. When I'm driving, the instrument light(speedometer) goes from 0% to 100% brightness for no reason.
    Can you please, take a look on this maps on channel 9 , which is done with i think pirate copy of VCDS, because i couldn't find mine and my friend borrow me his ..
    Thank you very much.
    Golf 7 2.0 TDI 6DSG Highline
    @ConfusedGolf: I don't knowingly work with any data from pirated equipment. My position is that the IP theft in any form is wrong and it should not be condoned, or supported.
    I'm aware that there are others here who don't share my position - perhaps they can help? Otherwise, provide the data from your legitimate VCDS cable
    Jun 2021
    Bulgaria
    Well, I will to find someone with licensed VCDS and do the maps again.. does this will help?
    @ConfusedGolf: Happy to work on data from a legit cable - but please also include a COMPLETE (meaning unedited) auto-scan. You can remove the VIN if you want.
    Jun 2021
    Bulgaria
    Well, friend of mine had VCDS and do me a favor to run an auto-scan for my issue :
    Code:
    Wednesday,30,June,2021,13:15:18:23435
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
    VCDS Version: 21.3.0.0
    Data version: 20210226 DS325.0
    www.Ross-Tech.com
    VIN:    License Plate:
    Mileage: 241269km-149917miles  Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
    VIN:  Mileage: 241269km-149917miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    Address 01: Engine    Labels:. 04L-907-309-V1.clb
    Part No SW: 04L 906 021 DT HW: 04L 907 309 D
    Component: R4 2,0L EDC H22 7545
    Revision: 83H22---
    Coding: 111D0032032405082000
    Shop #: WSC 00028 028 00204
    VCID: 7AFB47EFFDDF505645-802E
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 02: Auto Trans    Labels: 0D9-927-770.clb
    Part No SW: 0D9 300 041 P HW: 02E 927 770 AQ
    Component: DQ250-6F MQB H53 4507
    Revision: 05853104 Serial number: TFK01409151803
    Coding: 0014
    Shop #: WSC 00028 028 00209
    VCID: 2541449324E10FAE58-8070
    Address 03: ABS Brakes    Labels: 5Q0-907-379-IPB-V1.clb
    Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
    Component: ESC H31 0471
    Revision: 00000000 Serial number: 62724000000723
    Coding: 04FA62A1242509720377060741C82920462490C0608294F30062507AC202
    Shop #: WSC 00028 028 00248
    VCID: 4581E413C4A1EFAE78-8010
    Address 08: Auto HVAC    Labels:| 5G0-907-044.clb
    Part No SW: 5G0 907 044 AF HW: 5G0 907 044 AF
    Component: Climatronic H03 0912
    Revision: 00001K08
    Coding: 02020104202100011005004000101000
    Shop #: WSC 00028 028 00067
    VCID: 6BD572AB8285F9DECE-803E
    Fresh Air Blower Front:
    Geber für Kältemitteldruck/Kältemitteltemperatur:
    Air quality sensor:
    Address 09: Cent. Elect.    Labels:| 5Q0-937-08X-HV1.clb
    Part No SW: 5Q0 937 086 AA HW: 5Q0 937 086 AA
    Component: BCM PQ37BOSCH 028 0106
    Revision: -------- Serial number: 86580410140583
    Coding: 00001A42C24102FB4BE44000000C07081000000000000000000000000000
    Shop #: WSC 00078 790 12345
    VCID: 79F958E3F8D95B4E4C-802C
    Control Unit For Wiper Motor:
    Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
    Component: WWS 140905 043 0551
    Serial number: 140920203128
    Coding: 0E4DDD
    Rain Light Recognition Sensor:
    Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
    Component: RLHS 037 0059
    Serial number: S5Y14M10D10H15M24S43
    Coding: 00A8DD
    Relative Air Humidity Interior Sender:
    Address 10: Park/Steer Assist    Labels:| 5Q0-919-298.clb
    Part No SW: 5Q0 919 298 F HW: 5Q0 919 298
    Component: PARKHILFE PLA H12 0047
    Revision: -------- Serial number: 39431427100099
    Coding: 0031061051
    VCID: 428BFF0FD58FD8965D-8016
    Address 15: Airbags    Labels:| 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
    Component: AirbagVW20 014 0385
    Serial number: 003F6R0BNNP4
    Coding: 98CCC000000000005C0000CF004800000065
    Shop #: WSC 00028 028 00057
    VCID: 4189F003D089C38E44-8014
    Side Sensor Driver Front:
    Subsystem 1 - Part No SW: ----------- HW: 480 003 009 14
    Component: SideSensor_Df 001 0887
    Serial number: 3576700000080D44F01U
    Coding: 2D2D2D
    Side Sensor Passenger Front:
    Subsystem 2 - Part No SW: ----------- HW: 480 002 609 14
    Component: SideSensor_Pf 001 0887
    Serial number: 35867000000D2261111D
    Coding: 2D2D2D
    Side Sensor Driver Rear:
    Subsystem 3 - Part No SW: ----------- HW: 480 402 309 14
    Component: SideSensor_Dr 001 6149
    Serial number: 3516502BF176A6B4B06O
    Coding: 2D2D2D
    Side Sensor Passenger Rear:
    Subsystem 4 - Part No SW: ----------- HW: 480 402 409 14
    Component: SideSensor_Pr 001 6149
    Serial number: 3526502B3175A90393A8
    Coding: 2D2D2D
    Front Sensor Driver:
    Subsystem 5 - Part No SW: ----------- HW: 480 401 909 14
    Component: FrontSensor_D 001 6149
    Serial number: 3556502BD176A6B4A17R
    Coding: 2D2D2D
    Address 16: Steering wheel    Labels:| 5Q0-953-549.clb
    Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
    Component: Lenks.Modul 075 0175
    Revision: FF032032 Serial number: 20140926400075
    Coding: 0410
    VCID: 3F8DF6FBA67DB57E32-806A
    Address 17: Instruments     Labels:| 5G0-920-XXX-17.clb-SRI3
    Part No SW: 5G1 920 741 HW: 5G1 920 741
    Component: KOMBI 204 4270
    Coding: 07A511082B90000800086A001400000000000000
    VCID: 64C719976F5BB6A68F-8030
    Address 19: CAN Gateway    Labels:| 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
    Component: GW MQB High 212 2186
    Revision: -------- Serial number: 02101410800859
    Coding: 030100040B087300EF00024A1C0F00010001050000000000000000000000
    Alternator:
    Multi Function Steering Wheel Control Module:
    Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
    Component: E221__MFL-DC1 H16 0038
    Serial number: 27140002390380024391
    Coding: 28FFFF
    Battery Monitoring Control Module:
    Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
    Component: J367-BDMHella H03 8043
    Serial number: 6711464603
    Address 42: Door Elect, Driver    Labels:| 5QX-959-X93-42.clb
    Part No SW: 5Q4 959 593 C HW: 5Q4 959 593 B
    Component: TSG FS 009 0015
    Serial number: 0000119708121
    Coding: 003B0320D000020000001000
    Drivers Door Rear Control Module:
    Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
    Component: Fond FHSG DRV 007 0002
    Serial number: 00000000000006743261
    Coding: 010000
    Address 44: Steering Assist    Labels:| 5Q0-909-144.clb
    Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
    Component: EPS_MQB_ZFLS 123 1043
    Coding: 0303
    Address 52: Door Elect, Pass.    Labels:| 5QX-959-X92-52.clb
    Part No SW: 5Q4 959 592 C HW: 5Q4 959 592 B
    Component: TSG BFS 009 0015
    Serial number: 0000119616374
    Coding: 003B0120DE00020000801000
    VCID: 4487F917CF9BD6A66F-8010
    Passengers Rear Door Control Module:
    Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
    Component: Fond FHSG PSG 007 0002
    Serial number: 00000000000006686744
    Coding: 090000
    Address 55: Headlight Range    Labels:| 7P6-907-357.clb
    Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
    Component: AFS-ECU H07 0090
    Revision: -------- Serial number: --------------
    Coding: 069800000B000200
    VCID: 408FF507DB83CA864B-8014
    Left Headlamp Power Output Stage:
    Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
    Component: LeiMo links H01 0002
    Coding: 2E0000
    Right Headlamp Power Output Stage:
    Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
    Component: LeiMo rechts H01 0002
    Coding: 2E0000
    Address 5F: Information Electr.    Labels:| 5G0-035-MIB-STD1.clb
    Part No SW: 5G0 035 846 A HW: 5G0 035 846 A
    Component: MU-S-N-ER 041 0430
    Serial number: V1F02809140617
    Coding: 02730201FF00000011110001000800001F0100840100010045
    VCID: 275D4E9B5EED1DBE6A-8072
    Operating And Display Unit 1:
    Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
    Component: ABT_Std_Nav H60 0030
    Serial number: VWZ8Z9PS4041SQ
    Data medium:
    Subsystem 2 - Part No SW: 5G0 919 866 BD HW: -----------
    Component: ECE 2020/21 --- 0094
    Serial number: --------------------
