@deadcat: hmm........if I'm reading the installation sheet correctly, it ain't quite as you describe in your original post (no offense intended).
You said this:
Originally Posted by
deadcat
The instructions in the box advise that I need to wire as follows:
- Run new wire from BCM (connector C). Remove pin 9. Remove pin 3, and insert into pin 9. Put new wire into pin 3,
But the instructions say (I think):
- Run new wire (yellow) from BCM (connector C).
- Remove wire on pin 9.
- Remove wire on pin 3, and insert into (vacant) pin 9 position.
- Insert wire from (old) pin 9 into (vacant) pin 3 position.
- Put new wire (yellow) into pin 6 position - which presumably was factory vacant.
So, which of the two methods did you actually implement?
Still very confusing - but from the vehicle picture, it appears that the yellow wire is connected to all 4 x tail-light fittings. I'm guessing therefore that the yellow wire is +ve VOLTS (T15 volts maybe?). Because the yellow wire is connected to BCM pin 6 (Socket C), it will be controlled by Leuchte27NSL RC6. So you will need to activate this Leuchte-set and add the Leuchte-command for T15 volts - which is Klemme 15 ohne Nachlauf.
The new Blue wire joins together lamps on both inner/outer fittings on the left-side and the White wire does the same on both right-side fittings. But I'm not sure which lamps are joined given that you say that the tail-lights fittings have "no inner indicator lights".
I assume that the lighting functions for the individual lamps on the new outer and inner fittings are:Outer:
- Brake
- Turn Signal
- Parking Light
Inner:
- Parking Light
- Reverse
- Fog (right-side only)
Is this correct for the new fittings (do you have a diagram of the lighting positions for the new fittings)?
As you can see, the only common lighting function in the outer/inner fittings is the Parking Light - maybe the Blue/White wires replace the wires in the native vehicle loom for the inner Parking Lights. If so, Leuchte23SL HLC10 and Leuchte24SL HRA65 will need to be disabled (however, I'm not sure why this modification is used when the factory method for illuminating the Parking Light on the inner fitting works perfectly well without the need for the blue/white wires)
Final question - with the wiring completed and with no coding changes, describe how each lamp operates - please. And what errors appear on the SCAN report for this car?
