^^^Fashionci:thanks for the kind words - but as you can see from my attributions in the VCDS reference thread, many tweaks are authored by other colleagues (so the thread content is really a forum community exercise)
OK - as to your not so "odd idea", I don't have a definitive answer because I don't know what model car you drive, or the country of sale (where is "Mel, QL"?). However, at least for mk7s, the problem is that the Front-Field-Lights on the wing mirrors are connected to the driver & passenger side door control modules (@ address hex42 and hex52).
From memory, I don't recall that there are any physical wire connections between the door modules and the BCM (@ address hex09) - notwithstanding that the BCM does control car locking (so the BCM is wired to the door locks, sill lights etc). This means that the only way to get the reversing signal to the door control modules is via a CAN message - but again for mk7s down here in the Antipodes, there are no Leuchte-sets in either the driver, or passenger door modules to receive this message. So alas, I don't think the tweak is possible.
One of my tweaks on the VCDS thread is to co-opt the high level Brake light as a reversing light. I found that using the 3rd Brake light when reversing provided extra "general illumination" - which helped when backing the vehicle,.
The other way of achieving (at least in part) illumination at the side of the vehicle is to switch-on the front fog lights when reversing. Fog lights (if fitted) have a wide lateral spread pattern that lights-up the side of the vehicle and they are used as static cornering lights for this reason.
If you are using static AFS on your car - try changing IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt to the value, on in the BCM.
