My mistake I see what you mean now.
2012 MKVI Golf Comfortline 118 TSI
Can someone help me with 3rd brake light tweaks?
I did some coding (mostly enabling 3rd brake light when boot is open and also for coming/leaving home).
I tried to enable it for hazard lights but it now is active while using turn signals too.
Komoornik: bummer!! If you used my tweak instructions - then I've received many responses confirming that they work OK.
There are lots of ways that the tweak could go wrong - perhaps the best way to fix the problem is to post-up the FULL Leuchte-set values on your car at present (by which I mean the complete 19 x adaptation channels for Leuchte22BR MA57). You can either copy-and-paste the channels and their values into a post, or include pictures (probably need 3 x pics)
So any tail-gating birds don't crash into the rear of the car!!!
Here are the screenshots.
BTW is there an adaption channel for cornering lights from the main lamps? I have LED TOP installed.
Ok now the 3rd brake light is off. So how to enable the blinking with hazard lights only? I want to keep it on when boot is opened or for coming/leaving home.
I mean the cornering lights which are turned on when moving a steering wheel (not the fog lights).
