zac: Hi.
No, I don't believe that it's a "mk7.5 thing" albeit if the hex05 module in your mk7R doesn't have the adaptation channels in my instructions below - that might be the problem!
Try this:
Ignition ON/OFF button (KESSY): activate heart-beat pulse
- Go to the KESSY module Acc/Start Auth. @ address hex05
- Select Security Access
- Enter the magic number 20103
- Select Adaptation
- Change the channels below to activated
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt- Exit VCDS - the button starts it's heat-beat pulse immediately after the changes are made
