Page 170 of 198 FirstFirst ... 70120160168169170171172180 ... LastLast
Results 1,691 to 1,700 of 1974
  1. #1691
    Jul 2015
    Lex: Hi. hmm.........while the curve_adjustment channels do allow some flexibility to the illumination thresholds on the dashboard, I'm not sure that they were ever meant to be very sophisticated.
    I suspect that your fairly unique "wants" might be outside the capabilities of what is possible - but I'm more than happy to be proven wrong! So I suspect that you may need to accept some form of compromise to your (fairly unique) wants and ultimately I think that you will need to apply changes to a combination of functions - but I'm just guessing.
    However, there are a group of similar channels in the hex5F module that might be worth investigating in conjunction with the hex17 module channels. I've not experimented with the hex5F channels below - so I can't be definitive as to whether they will help:
    ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1
    ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5
    ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6
    ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5
    ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6
    Again, this just a suggestion (guess, really), but I'd welcome any feedback from your experiments -please
    Hi Don, I tried the addresses you suggested but I just kept getting a security access code required. I tried using S12345 as VCDS suggested and although it accepted that code it still came up asking for a code once I tried changing values. Do you have a code I could try?
  2. #1692
    ^^^ I have posted a fulsome set of security codes for MQB platform vehicles (like the mk7) on the Ross-Tech forum HERE.
    If you can't access this part of the RT forum, an earlier version of my security code list can be found HERE
  3. #1693
    Oct 2019
    Ormond Beach, FL USA
    Referring to this post here.
    I just coded option 1 and 2 of the Fog Light Tweak on my NAR spec MY19 GTI with the LED headlamps / fog lamps with success!
    2019 Golf 7.5 GTI Rabbit Edition Pure-Weiß 2016 Golf 7 Variant R-Line Pure-Weiß 2011 Golf 6 TDI BLUEMOTION Highline Candy-Weiß 2008 Golf 5 .:R32 Deep Blau Perleffekt DSG 4-MOTION 2006 Golf GTI DSG Tornadorot 2002 Indigo Blau Perleffekt Passat 3BG Trendline.
    I
    Euro-spec Mods!
  4. #1694
    Oct 2019
    Thanks for the admap (I'll add it to the others in my database)
    For the boot-lid open tweak - do this (bracketed entries are your default values):
    ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 > Heckdeckel offen (not active)
    ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 > 100 (0)
    ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 > Heckdeckel offen (not active)
    ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 > 100 (0)
    For the fog light tweak, just follow my instructions HERE
    For the 3rd Brake light tweak try this (although I have received feedback that the first 2 x options can be problematic on some mk7.5s):
    Boot-lid open tweak works!
    Fog light tweak works!
    3rd brake light tweak half works and you did mention it could be problematic. After going through the coding chart to compare my stock values against the tweaks I noticed something odd. ENG116302-Leuchte 22BR MA57-Lichtfunktion F 22 stock value was "Ruekfahrlicht" and not set to "Not Active". I went ahead and coded it to "Blinken rechts Dunkelphase" per the instructions and after coding everything else the only visible tweak results are:
    1. When using L or R turn signal the 3rd brake light flashes in sequence (didn't really want this because I feel it could confuse drivers??)
    2. Hazard button engaged flashed 3rd brake light in sequence with rear turn signals (does not work)
    3. Rear turn signals flash in sequence with 3rd brake light (does not work)
    Attached Thumbnails Attached Thumbnails VCDS (VAG-COM) codes and programmable options for Golf Mk7-29jkqnkpng1-1-jpg
    I
    Euro-spec Mods!
  5. #1695
    Oct 2019
    netherlands
    Hello, I've got a question about the headlights on my golf 7.5 with "simple led" I've got the \_ _/ and not the \_\_ _/_/. Now is my question:
    I want my white drls orange and when I turn the blinkers on it needs to be blinking white. Just the opposite of default from factory. (here in EU) But the most important what I want is that the Amber (corner lights) shining always. Same as US standlight golf 5. I've searched everything but I can't find it. I only find it for the golf 7. Not the 7.5 with led (lowbeam)
  6. #1696
    Oct 2016
    New Zealand
    Is there a way to keep the reverse camera on when flicking from reverse to drive? My Kodiaq keeps the cameras on till around 15kph, which I've found to be nice when doing multiple-point manoeuvres.
  7. #1697
    Oct 2019
    Anyone know how to get the ignition push start to pulse like a heartbeat? Some SEAT models do this and I've seen videos of people coding this to their VW models but not sharing the code.
    Sent from my SM-G965U using Tapatalk
    I
    Euro-spec Mods!
  8. #1698
    Oct 2019
    Quote Originally Posted by quailallstar View Post
    Nevermind! Don have me the codes and I can confirm it works. Posted it on YouTube.
    YouTube
    I
    Euro-spec Mods!
  9. #1699
    Oct 2016
    New Zealand
    YouTube
    Doesn't work for me on my Mk7R - is this a Mk7.5 thing?
    2015 VW Golf R Wagon - Deep Black Metallic - Stage 1 257kW 470Nm
    2019 Skoda Kodiaq RS - Brilliant Silver Metallic - Ignite rims, Sunroof, Direct TPMS, Acoustic Windows
  10. #1700
    Quote Originally Posted by zacdaman View Post
    Try setting this adaptation to enabled in 5F infotainment:
    IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B
