Page 168 of 198 FirstFirst ... 68118158166167168169170178 ... LastLast
Results 1,671 to 1,680 of 1974
  1. #1671
    Quote Originally Posted by vert1 View Post
    Anyone on here own a manual 7.5 Original GTI?
    Hoping someone can do an autoscan on their car or may have a saved copy.
    Converted mine to manual and want to compare some long coding.
    Assuming that you use the release version of VCDS software (not the Beta, or Test versions) - have you tried looking in the directory Ross-Tech\VCDS\Scans on the laptop that you use with the diagnostic cable? That's where old auto-scan reports that you have made in the past are stored
    And if that fails, try looking in Ross-Tech\VCDS\logs - there's a bunch of stuff in this directory about your past activity with the cable. Perhaps one of these files - like an adaptation channel map, or a Log.txt file - has what you seek
    And if that fails, try opening Codinglog.CSV in the directory Ross-Tech\VCDS\debug with a higher order application like MS Excel. This file contains a complete database of all the Byte/Bit changes that you have made with your cable to the hex02 module (using that laptop). The records contain the "before" values - so this might be of interest in respect of original module code-strings on your mk7.5?
    PS: and if you have in the past, or you currently do use the Beta, or the Test version VCDS software - the appropriate directories for the locations above are Ross-Tech\VCDS-Beta\*, or Ross-Tech\VCDS-Test\*.
  2. #1672
    Mar 2010
    auckland NZ
    Hi Don
    Thanks for your reply, I have an autoscan for my car so thats no problem.
    What I'm actually after is for someone on here to Autoscan their Manual Original Edition GTI so that I can then compare some of their
    long coding to my long coding (from when mine was still DSG) to hopefully solve the last of my error codes.
  3. #1673
    I was hoping someone would know if it is possible for the parking lights to remain full brightness when the fog lights are activated. Specifically on a 2019 mk7.5.
    Thank you!
  4. #1674
    Sep 2019
    Canada
    Hello Don,
    I am new here and have a question for you already. After coding, via OBD Eleven, my Brakelights ( all 5 lit ) as well as my Signallights ( sequential flashing ), I noticed, standing beside the vehicle, there is a very small " window " in the outside taillight that flashes on the opposite side from the active turnsignal. Is there a cure for this ?
    Thank you
    Manny ( Tiguanfahrer )
  5. #1675
    Quote Originally Posted by Tiguanfahrer View Post
    Hello Don,
    I am new here and have a question for you already. After coding, via OBD Eleven, my Brakelights ( all 5 lit ) as well as my Signal lights ( sequential flashing ), I noticed, standing beside the vehicle, there is a very small " window " in the outside taillight that flashes on the opposite side from the active turn signal. Is there a cure for this ?
    Thank you
    Manny: Hi and thanks for the PM.
    It's been a long time since I was last asked this question and I'm having problems finding the solution in my notes. But you could try the following:
    In the Cent. Elect. module (BCM) @ address hex09 - enter the magic number 31347 as a security code, then go to adaptations-10.
    Assuming your mk7 is built after MY16, search for Aussenlicht_Heck. Select ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion and change to active
    If this doesn't work -try this:
    Assuming your mk7 is built after MY16, search for Aussenlicht_Heck. Select ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht and change to yes
  6. #1676
    Sep 2019
    Canada
    Hi Don,
    Thank you for getting back to me with your suggestions. However, I tried the first option, which is an available option, but it does not work.
    The small LED ? in the little sidewindow keeps flashing left when I engage the right-turn signal and viceversa on the other side.
    Maybe I will just have to live with it ....EH ?
    Thank you
    Manny
  7. #1677
    Sep 2019
    GREECE
    How and where to register mine Alpine X901D-G7 navigator ?
    Hello.
    I have change in my car the Radio Composite Colour (which was without navigator) with the Apline X901D-G7 navigator.
    Alpine has full CANBUS ability and works very fine with the steering controls and the MFD. I Think some Car setup menus are missing.
    Where / how to tell to the canbus(?) there is a alpine navigator installed?
    If i go to 37 Navigation, i got a error(maybe because there was only a radio before installed and no navigator)
    Point 37- Navigation, does not appears automatically (only if i select this, in the Gateway List)
    VCDS (VAG-COM) codes and programmable options for Golf Mk7-snap5-jpg
    VCDS (VAG-COM) codes and programmable options for Golf Mk7-snap6-jpg
    VCDS (VAG-COM) codes and programmable options for Golf Mk7-snap4-jpg
  8. #1678
    ^^^^ marsias: not sure what's happening with your car - your first picture doesn't show that the MIB is registered in the CAN Gateway module - you don't mention what type of vehicle this is - the second picture suggests that you either have a pirated cable, or if it's genuine, its out of date - and in any event, SATNAV facilities on OEM MIB units for MQB platform vehicles don't usually have a separately registered control module @ address hex37.
    So -it's all a tad strange! Perhaps you should post-up a COMPLETE (meaning totally unedited) copy of an auto-scan for the vehicle. AND also some information about the car itself.
  9. #1679
    After market units don't need to be registered in canbus gateway installation list.
    They just respond to can messages on the bus.
  10. #1680
    Sep 2019
    GREECE
