Page 165 of 198 FirstFirst ... 65115155163164165166167175 ... LastLast
Results 1,641 to 1,650 of 1974
  1. #1641
    Feb 2019
    Very interesting, and yes, I can see what you mean about introducing aftermarket lights into the mix, and being relatively unsure of the outcome. The 2B option definitely was the one that did the trick for me. With the switch on Auto, in the daylight only the Double U DRLs are active. Then drove into an underground car park and the low beams come on as they should.
    As these Supernova headlights are based on Aussie Golfs, I'm sure it allows them to match up wires as best as possible to work plug and play, and they basically do. What I also found interesting (but not surprising) is when you look at a picture of the new lights, the DRL is supposed to be on the Leuchte2SL & Leuchte3SL channels(?). However, because these are not OEM lights etc.. to actually adjust the brightness of the DRLs is under the Leuchte4TFL & Leuchte 5TFL -> Dimmwert EF 4. Which is obviously the same channel for setting the Halogen DRL brightness when they were installed.
    I can see the interest in all of this coding and design, and if I was ever going to learn German, this is not a bad way to go about it.
  2. #1642
    Jul 2018
    Quote Originally Posted by Whisp View Post
    When in the off position, the DRLs are on, full brightness.
    When in the Auto position, the low beams are on, regardless of time of day.
    When in the Parkers(?) position, the DRLs are on, full brightness.
    And dipped beams, normal low beam again.
    Did you get it so that when your switch is set to off, the DLR are off? I dont know if my old halogens turned off when set to off as they were not bright to ever notice.
  3. #1643
    Aug 2017
    Uk
    Got it working
    Ok to get the footwell and door brightness sliders you need to change these 2 to from 0 to 8x1 (11111111, although I have tried any other 8 figure binary and it seems to work), IGNORE THE PATTERN OF 0-255 that Obdeleven puts up
    Central electronics
    Interior lighting, parameter:
    p_ambientelicht_verbauinformation_HMI:
    11111111 (default is 0, and this one is for footwell)
    p_ambientelicht_verbauinformation_HMI_2:
    11111111 (default is 0, and this one is for the door)
    I’m sure HMI_3 & 4 will put the settings cog on for other lights like maybe Center console if you had them in your car
    Now you will have the cogs on the brightness screen, but the glow will be WHITE
    Now if you want the glow on the screen to be the same colour as your display (like my pictures are green down there vvv)
    p_ambienteumfang_mehrfarbig_HMI:
    100 (default is 0, footwell)
    p_ambienteumfang_mehrfarbig_HMI_2:
    100 (default is 0, door)
    There you go independent footwell and door lighting with colour change
  4. #1644
    Aug 2017
    Uk
    YouTube
    done a video if it helps
  5. #1645
    Feb 2018
    Melbourne, vic
    does the ambient light in the footwell change colour or are the factory leds not rgb? can you post a picture if they do.
  6. #1646
    Feb 2018
    The LED in the footwell/door are not RGB so you can't change the colour to correspond the console/head unit (confirmed by VW mechanic). I'm keen to know how/where to purchase the required RGB LED (or whether you need a whole new door card which won't be cheap) so that they can be interchangeable with the rest. Thanks for the codes they worked a treat and look good. My favourite is electric lime. I used the following website to come up with my own 10 colour schemes...
    RGB Color Codes Chart
    VCDS (VAG-COM) codes and programmable options for Golf Mk7-20190405_1845041-jpg
    MY18 Golf R Wolfsburg Edition (Oryx White Pearl)
  7. #1647
    Aug 2017
    Uk
    Yeah I was looking the other day
  8. #1648
    Apr 2019
    Switzerland
    rror: Adaptive Front Lighting (AFS)
    Good evening!
    I have a 2013 GTI Golf, and I decided to change the AFS light because I had changed some lights and... then I decided to put a LED!But... there's a problem!
    I've changed the AFS H7 to an LED! and the error appears because of the voltage indications, I think!
    There is a way using Vagcom/VCDS to solve the error of AFS?
    Some one to help?
    Best regards
  9. #1649
    david: hi - can you post-up the actual error message? Even better, perhaps a copy of the autoscan results for the car so we can see how you coded the BCM.
  10. #1650
    Apr 2019
    Switzerland
    Hi @DV52 this is the error message that the VCDS gives to me...
    VCDS (VAG-COM) codes and programmable options for Golf Mk7-afs-error-msg-jpgVCDS (VAG-COM) codes and programmable options for Golf Mk7-car-error-jpg
    Thank you so much! Hope that some one can help me!
    Best regards
    David Gonçalves
    Attached Thumbnails Attached Thumbnails VCDS (VAG-COM) codes and programmable options for Golf Mk7-screenshot-2019-04-12-17-30-53-png
