Page 155 of 198 FirstFirst ... 55105145153154155156157165 ... LastLast
Results 1,541 to 1,550 of 1974
  1. #1541
    Apr 2014
    Albany Creek, Qld
    Quote Originally Posted by Sage View Post
    could someone please confirm to disable the Saftey Nag screen you need to change the actual code to "00"?
    Yes - Byte 23 gets changed from "02" (in my case - might be different for you) to "00" to disable the Nav Nag screen.
  2. #1542
    Nov 2017
    Coffs Harbour NSW
    00 worked for me too. Worth the price of the OBDEleven.
  3. #1543
    Apr 2009
    Thanks guys!
  4. #1544
    Sep 2012
    How about getting rid of the "look! safe to move?" line when using the rear camera or parking sensors?
    MY13 Golf GTI DSG (SOLD)| Candy White | 18" Detroits | Bi-Xenon Headlights | Street Guardian SG9665C
    MY18 Golf R DSG | Indium Grey | 19" Spielbergs | DAP | Sunroof | Viofo A119v2 (front) | BlueSkySea B1W (rear)
    Micro-CAN VCDS
  5. #1545
    May 2017
    Has anyone got 5 brake light working on the 7.5 facelift, people were going to try but I have not seen a follow up?
  6. #1546
    Sep 2012
    Quote Originally Posted by Rufus1000 View Post
    I do. I posted it around here somewhere.
    Sent from my SM-G950F using Tapatalk
    Micro-CAN VCDS
  7. #1547
    Aug 2017
    Uk
    On mine there is no LED on one side and on the other it’s a fog light, plus there’s a big gap in between so doesn’t look right
  8. #1548
    Sep 2012
    Quote Originally Posted by Jap View Post
    Oh, unfortunately the dynamic LED tail coding is different from the standard tails.
    Micro-CAN VCDS
  9. #1549
    Aug 2017
    Uk
    Quote Originally Posted by Kevlarman View Post
    ah as I don’t have dynamic I don’t know
  10. #1550
    Oct 2012
    Quote Originally Posted by bgroper View Post
    STF for "soundaktor".
    HTH
    What do you mean by the above?
    According to the link, the following should work:
    Go to:
    - A9 Struct. Borne Sound
    - Adapation 10
    - Select "channel of structure borne sound " (only choice)
    - Std value 100% - change to the value you want stored in % (60% has been suggested as a good happy medium, adjust to 0% if you want no noise/mini vibrations).
    - "Use change code for change approval"
    However, the VCDS doesn't have - A9 Struct. Borne Sound for some reason :s
