AFAIK Pedestrian Assist is only included in MY18.5 cars (built in/after November 2017).
2017 MY18 Golf R Wolfsburg | Oryx White | DSG / 2021 MY21 T-Cross Style | S+V Package | Limestone Grey
2017 Tiguan Highline 162TSI DAP, Sunroof, Black
2018 Golf Comfortline 110TSI DAP, Infotainment, Silver
wow - what an amazing thread some very talented individuals here. though i have a request if someone would like a challenge.. Anyone seen a setting which will allow the USB Port for the Discovery to stay powered when engine is off? (mk7 Golf) I think it stays on for about 10 minutes once the engine is off though i want it on permanently or at least for a couple of hours.. anyone seen a setting?
(Ps. I already did the fuse change for the cigarette lighter!)
Thanks all.
2005 MkV Golf 2.0TDi 103 - DSG - Heated Leather - Tint - Audi 17" - Lowered - Bluefin Tune.
2016 MkVII Golf 2.0TDi 110 - Wagon. Fully Optioned. Lowered on Eibachs. RS3 Black 18s. Mk8 Head Unit. VCDS Tweaks - Bluefin Tune
Hi all, I've recently bought a brand new MK7.5 comfortline with DAP and I wanted to implement the 5 brake light mod.
I have tried 2 methods (this and that) so far without any luck and I was hoping someone could help me out.
My golf has the standard LED tail lights.
Below are some screenshots of the current settings in OBD eleven.
Thanks for all your hard work guys.
ashee/Blackpaladin67:
I don't have access to a mk7.5 at the moment, but just from a theoretical perspective, you might try the following
Leuchte24SL HRA65
Existing Setting New Setting Lasttyp 24 43-allgemeine LED 34 - LED Bremsleuchten Lampendefektbitposition 24 1A 1A Fehlerort mittleres Byte DTC-DFCC 24 2A 2A Lichtfunktion A 24 Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht) Brake light/Bremslicht Lichtfunktion B 24 Parklicht rechts not active Dimmwert AB 24 127 100 Lichtansteuerung HD AB 24 Always Always Lichtfunktion C 24 not active Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht) Lichtfunktion D 24 not active Parklicht rechts Dimmwert CD 24 0 10 Dimming Direction CD 24 maximize maximize Lichtfunktion E 24 not active not active Lichtfunktion F 24 not active not active Dimmwert EF 24 0 0 Dimming Direction EF 24 maximize maximize Lichtfunktion G 24 not active not active Lichtfunktion H 24 not active not active Dimmwert GH 24 0 0 Dimming Direction GH 24 maximize maximize Leuchte23SL HLC10
Existing Setting New Setting Lasttyp 23 43-allgemeine LED 34 - LED Bremsleuchten Lampendefektbitposition 23 A A Fehlerort mittleres Byte DTC-DFCC 23 29 29 Lichtfunktion A 23 Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht) Brake light/Bremslicht Lichtfunktion B 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) not active Dimmwert AB 23 127 100 Lichtansteuerung HD AB 23 Always Always Lichtfunktion C 23 not active Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht) Lichtfunktion D 23 not active Parklicht links (beidseitiges Parklicht aktiviert li & re) Dimmwert CD 23 0 50? (choose a value to suit) Dimming Direction CD 23 maximize maximize Lichtfunktion E 23 not active not active Lichtfunktion F 23 not active not active Dimmwert EF 23 0 0 Dimming Direction EF 23 maximize maximize Lichtfunktion G 23 not active not active Lichtfunktion H 23 not active not active Dimmwert GH 23 0 0 Dimming Direction GH 23 maximize maximize
Please note that I have suggested that you reset the illumination level for Dimmwert CD on both Leuchte to a new value. Just from sitting here thinking about the change, it seems that you need a different illumination level between the Brake light function and the Parking light function - else the driver at the rear won't be able to easily distinguish from the inner lights when you are braking (hope this makes sense).
Anyhow try the above suggestion first. If my table above doesn't work - the other way that you might try is to simply copy the settings from the 2 x Brake lights onto the 2 x Leuchte-sets above (of course without changing Lampendefektbitposition or Fehlerort mittleres Byte DTC-DFCC channels )
Automatically adjusting the time and date for daylight savings time has just come up in this thread for cars with MIBII. It should also automatically adjust the time on interstate trips. Daylight Saving Time ?
Make sure you have the time reading off GPS in the settings.
Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
Thanks a lot Don, I'll try out your suggestions when I get home on Friday night.
