Page 152 of 198 FirstFirst ... 52102142150151152153154162 ... LastLast
Results 1,511 to 1,520 of 1974
  1. #1511
    Jul 2009
    QLD
    Golf R Mk 7.5 has the Driver Assistance Package. Using OBDeleven I noticed Pedestrian Assist is not enabled any thoughts welcome car built June 17 first of the Wolfsburgs. If someone can check a later build to see if it's activated?
    VCDS (VAG-COM) codes and programmable options for Golf Mk7-2018-03-26_1317-pngVCDS (VAG-COM) codes and programmable options for Golf Mk7-2018-03-26_1318-png
    2017 MY18 Golf R Wolfsburg | Oryx White | DSG / 2021 MY21 T-Cross Style | S+V Package | Limestone Grey
  2. #1512
    May 2017
    AFAIK Pedestrian Assist is only included in MY18.5 cars (built in/after November 2017).
    2017 Tiguan Highline 162TSI DAP, Sunroof, Black
    2018 Golf Comfortline 110TSI DAP, Infotainment, Silver
  3. #1513
    Jul 2009
    QLD
    Quote Originally Posted by sharp View Post
    Thanks for the update, guess it's got some extra hardware and software not a big one just curious
  4. #1514
    Apr 2009
    wow - what an amazing thread some very talented individuals here. though i have a request if someone would like a challenge.. Anyone seen a setting which will allow the USB Port for the Discovery to stay powered when engine is off? (mk7 Golf) I think it stays on for about 10 minutes once the engine is off though i want it on permanently or at least for a couple of hours.. anyone seen a setting?
    (Ps. I already did the fuse change for the cigarette lighter!)
    Thanks all.
    2005 MkV Golf 2.0TDi 103 - DSG - Heated Leather - Tint - Audi 17" - Lowered - Bluefin Tune.
    2016 MkVII Golf 2.0TDi 110 - Wagon. Fully Optioned. Lowered on Eibachs. RS3 Black 18s. Mk8 Head Unit. VCDS Tweaks - Bluefin Tune
  5. #1515
    Apr 2018
    Perth
    Hi all, I've recently bought a brand new MK7.5 comfortline with DAP and I wanted to implement the 5 brake light mod.
    I have tried 2 methods (this and that) so far without any luck and I was hoping someone could help me out.
    My golf has the standard LED tail lights.
    Below are some screenshots of the current settings in OBD eleven.
    Thanks for all your hard work guys.
  6. #1516
    Dec 2017
    QLD Australia
    Quote Originally Posted by monkeysrus View Post
    This drives me nuts as well.
    Mine just stopped doing this after the latest factory software update it was very annoying !
  7. #1517
    ashee/Blackpaladin67:
    I don't have access to a mk7.5 at the moment, but just from a theoretical perspective, you might try the following
    Leuchte24SL HRA65
    Existing Setting New Setting
    Lasttyp 24 43-allgemeine LED 34 - LED Bremsleuchten
    Lampendefektbitposition 24 1A 1A
    Fehlerort mittleres Byte DTC-DFCC 24 2A 2A
    Lichtfunktion A 24 Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht) Brake light/Bremslicht
    Lichtfunktion B 24 Parklicht rechts not active
    Dimmwert AB 24 127 100
    Lichtansteuerung HD AB 24 Always Always
    Lichtfunktion C 24 not active Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
    Lichtfunktion D 24 not active Parklicht rechts
    Dimmwert CD 24 0 10
    Dimming Direction CD 24 maximize maximize
    Lichtfunktion E 24 not active not active
    Lichtfunktion F 24 not active not active
    Dimmwert EF 24 0 0
    Dimming Direction EF 24 maximize maximize
    Lichtfunktion G 24 not active not active
    Lichtfunktion H 24 not active not active
    Dimmwert GH 24 0 0
    Dimming Direction GH 24 maximize maximize
    Leuchte23SL HLC10
    Lasttyp 23 43-allgemeine LED 34 - LED Bremsleuchten
    Lampendefektbitposition 23 A A
    Fehlerort mittleres Byte DTC-DFCC 23 29 29
    Lichtfunktion A 23 Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht) Brake light/Bremslicht
    Lichtfunktion B 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) not active
    Dimmwert AB 23 127 100
    Lichtansteuerung HD AB 23 Always Always
    Lichtfunktion C 23 not active Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
    Lichtfunktion D 23 not active Parklicht links (beidseitiges Parklicht aktiviert li & re)
    Dimmwert CD 23 0 50? (choose a value to suit)
    Dimming Direction CD 23 maximize maximize
    Lichtfunktion E 23 not active not active
    Lichtfunktion F 23 not active not active
    Dimmwert EF 23 0 0
    Dimming Direction EF 23 maximize maximize
    Lichtfunktion G 23 not active not active
    Lichtfunktion H 23 not active not active
    Dimmwert GH 23 0 0
    Dimming Direction GH 23 maximize maximize
    Please note that I have suggested that you reset the illumination level for Dimmwert CD on both Leuchte to a new value. Just from sitting here thinking about the change, it seems that you need a different illumination level between the Brake light function and the Parking light function - else the driver at the rear won't be able to easily distinguish from the inner lights when you are braking (hope this makes sense).
    Anyhow try the above suggestion first. If my table above doesn't work - the other way that you might try is to simply copy the settings from the 2 x Brake lights onto the 2 x Leuchte-sets above (of course without changing Lampendefektbitposition or Fehlerort mittleres Byte DTC-DFCC channels )
  8. #1518
    Dec 2017
    QLD Australia
    Leuchte24SL HRA65
    Dimmwert CD 24 0 10
    Dimmwert EF 24 0 0
    Dimmwert GH 24 0 0
    Leuchte23SL HLC10
    Dimmwert EF 23 0 0
    Dimmwert GH 23 0 0
    Thanks Don
  9. #1519
    Sep 2012
    Automatically adjusting the time and date for daylight savings time has just come up in this thread for cars with MIBII. It should also automatically adjust the time on interstate trips. Daylight Saving Time ?
    Make sure you have the time reading off GPS in the settings.
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
  10. #1520
    Apr 2018
    Perth
    Thanks a lot Don, I'll try out your suggestions when I get home on Friday night.
