Page 147 of 198 FirstFirst ... 4797137145146147148149157197 ... LastLast
Results 1,461 to 1,470 of 1974
  1. #1461
    Aug 2017
    Uk
    Quote Originally Posted by Kevlarman View Post
    Aren't the R tails dynamic? I have that cool "sweeping" turn signal.
    yes that’s dynamic, some earlier ones didn’t have dynamic
  2. #1462
    Quote Originally Posted by iant333 View Post
    I've tried (unsuccessfully) to get rid of the nag screen using VCDS (Ross-Tech V 18.1) but the info provided on this website about doing this process seems to be a bit old or maybe I'm just a bit dim? I am a newbie to this stuff but I have tried to follow the instructions and I don't see exactly the screens as provided. I don't have OBD2. I know it's boring but I have tried to find a clear explanation but have come up short. Is there anyone who could provide some screen shots of the process using the latest version. I have a 7.5R.
    iant: If you are using a HEX+CAN cable (the older product), the "normal" long coding helper screen for Byte 23 on the 5F module looks like this:
    Or, if you are using one of the HEX- V2/NET cable/dongles, the "yellow" long coding helper screen looks like this:
    regardless of which screen you access - simply set the value of Byte 23 to hex00 (or Binary 00000000)
    PS: If you are using a HEX+CAN cable on your mk7.5, I suggest that you upgrade to a HEX-V2/NET series devices. There are modules in this model that use the new OBD 2.0B protocols (29 Bit addressing) that the older cable can't read
  3. #1463
    Apr 2014
    Albany Creek, Qld
    Beat me to it - but this is it
  4. #1464
    Jun 2017
    Thanks for helping, however I feel like a lame novice here. I have a HEX-V2 (Firmware 18.1) I have tried many screens but I can't find the screen as illustrated. Sorry to bother you all again, but please would it be possible for you to briefly outline the menus and steps to take to get to these screens. I've tried and failed.
    Wolfsburg 7.5R. Lapiz Blue hatch DSG with sunroof.
  5. #1465
    iant: Not a problem - we have ALL been there at some stage in our VCDS learning-curve!!
    Here's a pictorial instruction that I hope is self explanatory. Please ask questions if further help is needed
    Note the numbered steps in the last screen - follow the numbers
  6. #1466
    Is it possible to enable static AFS lights for coming/leaving home on a MK7.5? Saw that somewhere for MK7.
    Also is it possible to enable both main beam and fog lights?
  7. #1467
    Jan 2018
    Chiapas
    New with OBD11, I have successfully codified almost everything, I have read all the pages of this forum and others, and as many I would like to thank the collaboration of DV52 and others that their contributions are remarkable.
    I wonder if someone could disable the legend of care when reversing. I read it in another site but it does not accept the access code, it's obviously wrong because it's out of range.
    *I speak Spanish, sorry my english
    https://imgur.com/a/1rhYg
  8. #1468
    Quote Originally Posted by tapachula View Post
    tapachula: hi . I have not seen your tweak instruction before. I've also not seen 71679 used as a security code in the ABS module @ address hex03.
    I have started a list of security codes HERE which you are welcome to try on your tweak instructions.
    Please be aware that control modules will lock-out if you enter the wrong security code. If this happens, the lock-out time can be upward of 20 minutes and the time is measured with the ignition switched-on
    Please provide feedback if your tweak instructions are successful
  9. #1469
    Sep 2012
    Those instructions appear to be from the Autoinstruct site.
    MY13 Golf GTI DSG (SOLD)| Candy White | 18" Detroits | Bi-Xenon Headlights | Street Guardian SG9665C
    MY18 Golf R DSG | Indium Grey | 19" Spielbergs | DAP | Sunroof | Viofo A119v2 (front) | BlueSkySea B1W (rear)
    Micro-CAN VCDS
  10. #1470
    Hide Optical Parking System Warning Line
    Disables the ‘Please check surroundings’ message that appears on the headunit when parking.
    Select Control unit 03 (Brakes)
    Security access
    Access code:71679
    Control unit Coding
    Byte 1
    Bit 5 DeActivate
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
