Thanks.
Is this only what I have to do?
5F Information Electr
Adaptations
(176)-Vehicle menu operation-menu_display_weariness_recognition = Activated
(177)-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off = Not Activated
(17-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_ high = Activated
(179)-Vehicle menu operation-menu_display_weariness_recognition_standstill = Not Activated
(180)-Vehicle menu operation-menu_display_weariness_recognition_after_disclaime r = Not Activated
Best Regards,
Chirag Geiantilal
'06 - Volkswagen Passat 3C 2.0 TDI Highline - 2009 - 2017
'12 - Volkswagen Golf VII 1.6 TDI Confortline - 2015 - ...
My question is:
Is just that what I have to activate or anything more?
Best Regards,
Chirag Geiantilal
Activated. It says function unavailable at moment. It means it's a SWAP (function as product, code nees to be bought) function?
When I try output test on module 19 of IDE05583-Pause Recommendation it says
Refused by Control module
Message 7F 2F 22
Any help?
Best Regards,
Chirag Geiantilal
MF: hmm........ I always get confused with American accents - it's my fault!!
The boot-open tweak part of the instructions in post #787 are the same as those in your copy of my instructions in the post above for NAR models. If the settings for the following channels on your car are as shown in the NAR Setting column in the table above - then it should be OK to proceed
(16)-Leuchte21BR RC8-Lichtfunktion G 21, and
(18 )-Leuchte21BR RC8-Dimmwert GH 21, and
(16)-Leuchte20BR LA71-Lichtfunktion G 20, and
(18 )-Leuchte20BR LA71-Dimmwert GH 20
For the tweak to work, the only important thing is that the G and H adaptation channels for the Leuchte21BR RC8 & Leuchte20BR LA71 Leuchte-set are not used before implementing the changes. I've given the "boot-open" function the highest priority in my instructions because I figure that it's the most important activity (i.e either the engine will be off, or the car will be stopped when the hatch is opened - so there will be no priority conflict with any other lamp function on the 2 x outer tails)
