Page 139 of 198 FirstFirst ... 3989129137138139140141149189 ... LastLast
Results 1,381 to 1,390 of 1974
  1. #1381
    Nov 2017
    NL
    Quote Originally Posted by cgentil View Post
    Anyone know if I can activate the fatigue detection system under Driver Assistance menu via VCDS or it's not possible?
    Thanks.
    You can turn it off in your car menu - drivers assist....i think
  2. #1382
    Sep 2017
    Portugal
    Quote Originally Posted by Rainesh View Post
    I don't have the option. I want to activate.
    Best Regards,
    Chirag Geiantilal
    '06 - Volkswagen Passat 3C 2.0 TDI Highline - 2009 - 2017
    '12 - Volkswagen Golf VII 1.6 TDI Confortline - 2015 - ...
  3. #1383
    Nov 2017
    NL
    Sorry did not read it right. Will check.it for you.
  4. #1384
    Sep 2017
    Portugal
    Thanks.
    Is this only what I have to do?
    5F Information Electr
    Adaptations
    (176)-Vehicle menu operation-menu_display_weariness_recognition = Activated
    (177)-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off = Not Activated
    (17-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_ high = Activated
    (179)-Vehicle menu operation-menu_display_weariness_recognition_standstill = Not Activated
    (180)-Vehicle menu operation-menu_display_weariness_recognition_after_disclaime r = Not Activated
    Best Regards,
    Chirag Geiantilal
  5. #1385
    Sep 2017
    Portugal
    My question is:
    Is just that what I have to activate or anything more?
    Best Regards,
    Chirag Geiantilal
  6. #1386
    Nov 2017
    NL
    My question is:
    I thought only that. Maybe in 17 also
  7. #1387
    Sep 2017
    Portugal
    Did you find out what?
    Best Regards,
    Chirag Geiantilal
  8. #1388
    Sep 2017
    Portugal
    Activated. It says function unavailable at moment. It means it's a SWAP (function as product, code nees to be bought) function?
    When I try output test on module 19 of IDE05583-Pause Recommendation it says
    Refused by Control module
    Message 7F 2F 22
    Any help?
    Best Regards,
    Chirag Geiantilal
  9. #1389
    I was recently acquainted with this tweak by a newbie forum member (thanks harisg). The tweak will illuminate the outer tail-lights (left & right) whenever the hatch is opened. This illumination happens regardless of the position of the rotary light switch, or the time-of-day (i.e. irrespective of whether the car has a RLS/RLHS/RLHS installed, or not). To the extent that the additional illumination provides a "visual" warning for approaching vehicles that a person is at the rear of the car, the tweak is considered a safety feature worthy of implementation.
    The tweak is straight-forward and easy to implement, but I have purposefully complicated these instructions to cater of our growing number of USA forum colleagues. As you may be aware, NAR (North American Region) cars have a slightly different lighting arrangement and the factory Leuchte settings for their outer tail-lights are more-functionally rich than our RoW (Rest-of-world)models - due in large part to the fact that the outer tail-lights must also perform the standard blinker activity
    A final point - once implemented this tweak will override the normal rear brake-light function. So if you drive with the tailgate opened, the tweak may not be appropriate!
    Tail-light illumination when hatch open - Safety feature
    1. Select 09 - Central Electr control module
    2. Select Security Access - 16 from the "Open Controller" screen
    3. Enter the magic number 31347 and return to the "Open Controller" screen
    4. Select Adaptation - 10 from the "Open Controller" screen
    5. From the pull-down button check that the default settings for the adaptation channels shown in the table below for either your RoW or NAR vehicle are as indicated in the RoW/NAR Setting column
    6. For the car type (i.e. RoW, or NAR), change the adaptation channels depicted in the table below to the values in the New Setting column (use the "Search" box to locate the correct channels)
    Notes:
    1. I've shown the complete Leuchte-set for both outer tail-lights for completeness, For confirmation though:
    • If the car is RoW:
    (5)-Leuchte21BR RC8-Lichtfunktion B 21 and
    (5)-Leuchte20BR LA71-Lichtfunktion B 20
    need to be changed
    • If the car is NAR,
    (16)-Leuchte21BR RC8-Lichtfunktion G 21, and
    (18 )-Leuchte21BR RC8-Dimmwert GH 21, and
    (16)-Leuchte20BR LA71-Lichtfunktion G 20, and
    (18 )-Leuchte20BR LA71-Dimmwert GH 20
    need to be changed
    2. If the default factory settings in the car are not as shown in the table- do not proceed with the tweak
    I wanted to set this but due to another tweak, tail lights operating in unison post #787 and the last line above I chose not to continue, any input appreciated
    MF
  10. #1390
    Quote Originally Posted by ManFriday View Post
    MF
    MF: hmm........ I always get confused with American accents - it's my fault!!
    The boot-open tweak part of the instructions in post #787 are the same as those in your copy of my instructions in the post above for NAR models. If the settings for the following channels on your car are as shown in the NAR Setting column in the table above - then it should be OK to proceed
    For the tweak to work, the only important thing is that the G and H adaptation channels for the Leuchte21BR RC8 & Leuchte20BR LA71 Leuchte-set are not used before implementing the changes. I've given the "boot-open" function the highest priority in my instructions because I figure that it's the most important activity (i.e either the engine will be off, or the car will be stopped when the hatch is opened - so there will be no priority conflict with any other lamp function on the 2 x outer tails)
