Page 135 of 198 FirstFirst ... 3585125133134135136137145185 ... LastLast
Results 1,341 to 1,350 of 1974
  1. #1341
    Nov 2017
    NL
    Quote Originally Posted by cgentil View Post
    Anyone can give me the parameters on VAG COM on how to regulate the volume of radio when OPS is engaged?
    Mine does that but it's aftermarket kit, and I'd like to know if with VAG COM I can disable this feature.
    Thanks.
    Check adaptions in module 10
  2. #1342
    Sep 2017
    Portugal
    Quote Originally Posted by Rainesh View Post
    Can't access that module because, but it's there.
    Maybe the module does it itself?
    My module is this one:
    Best Regards,
    Chirag Geiantilal
    '06 - Volkswagen Passat 3C 2.0 TDI Highline - 2009 - 2017
    '12 - Volkswagen Golf VII 1.6 TDI Confortline - 2015 - ...
  3. #1343
    Sep 2017
    Portugal
    Anyone know how to activate automatically hazard light when brake hard?
    Best Regards,
    Chirag Geiantilal
  4. #1344
    are you sure that you registered the new module in the CAN Gateway list when it was installed?
  5. #1345
    Sep 2017
    Portugal
    The module is not original. It's from GT Alarm.
    It does the same function as original module.
    Via VAGCOM I can't access that module because it's aftermarket and not original part.
    I tried to make active the parking sensor menu on radio car settings menu and the option does not appear, it's because that doesn't have information from module?
    Best Regards,
    Chirag Geiantilal
  6. #1346
    cgentil: OK - that being the case, why would you believe that the new module which appears to operate independent of the factory fitted Park Assist module and "doesn't have information from module" would allow VCDS access to address hex10?
    Clearly there must be a replication and/or thieving by the new module.of at least some of the CAN communications data that would normally be managed by the Park Assist module (J791).
    I have no idea how the CAN Gateway decides which data to divert to which module - is the GT Alarm module even connected to the running-gear-CAN-bus, or is it some form of LIN connection? If the latter, where is the comms wire from the GT alarm connected (i.e to which factory module is the GT Alarm module a slave)? If the former, how does the CAN Gateway resolve the conflict of two modules performing some of the same functions?
    And if there is no CAN/LIN connection to the car's substantive comms network from the GT Alarm module (OPS) at all, then why would you expect that access to the J791 module would allow for volume/frequency variation (if VCDS was able to see the hex10 address location)?
  7. #1347
    Jul 2009
    Can someone please post the VCDS code to disable the “nag” screens on the new Infotainment Pro in the new Golf.
  8. #1348
    Sep 2017
    Portugal
    Hi,
    Thanks for your reply. I only have that GT Alarm module.
    But there's some info's about this module:
    This is the kit they installed on car:
    This is the Park view Module GT alarm:
    Hope that can help.
    Best Regards,
    Chirag Geiantilal
  9. #1349
    cgentil: OK - as I suspected, the "GT Alarm module" is directly wired into the CAN bus.
    Try entering "10", or "76" into the "Direct Entry" box at the bottom of the Select Control Module screen (see below)
    Failing this - and I'm guessing again, but the new module must be thieving some of the CAN messages that would normally be the responsibility of the OEM module (i.e. J791). Clearly this has the side-effect of masking the module @ address hex10 from CAN Gateway module when it's performing the Diagnostic function. Very strange behavior, but probably something that can be best resolved through the GT alarm module manufacturer IMO. Non OEM - third party products can be tricky to fault-find (if this is indeed a fault- which it might not be)!
  10. #1350
    Sep 2017
    Portugal
    Thanks for reply mate.
    The module 10 it's appearing on VAGCOM but I can't access that module, it gives me error.
    But after this module installation, and I advised VW I got this error, and they said it's normal, it should be? I can't delete that error.
    19 CAN Gateway
    1 Fault Found:
    66304 - Databus
    U1124 00 [009] - Additional Installations Detected
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Supply voltage: Terminal 30: 12.0 V
    Terminal 15: On
    See this topic:
    GT Alarm Park View
    Best Regards,
    Chirag Geiantilal
