Page 130 of 198 FirstFirst ... 3080120128129130131132140180 ... LastLast
Results 1,291 to 1,300 of 1974
  1. #1291
    Jul 2015
    As I said in my previous response, I've found that the Leuchte-sets are not always allocated in the same way - especially for cars that have different versions of the HID headlight fittings.
    But generally, the "dot" Leuchte-sets are Leuchte8FL LB39 (left-side) and Leuchte9FL RB2 (right-side). Before I make a suggestion for your tweak, I'd ask that you confirm my guess about the Leuchte-sets.
    If I'm correct, your settings for the left-side dot should be as shown below. Please alter the Dimmwert AB value on your car to a small number. If I'm correct, you should see the dot illumination reduce on the left-side with the headlights switched-on. Revert the setting back to original and please advise your observation
    Adaptation channel
    Setting
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Parklicht links (beidseitiges Parklicht aktiviert li & re)
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127
    ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always
    Hi Don,
    I can confirm the Leuchte-sets on the Bi-Xenon headlights are Leuchte8FL LB39 (left-side) and Leuchte9FL RB2 (right-side) for the dot led. I kind of jumped ahead then and set Leuchte8FL LB39-Lichtfunktion C 8 and Leuchte9FL RB2-Lichtfunktion C 9 from "not active" to "daytime running light" and then Leuchte8FL LB39-Dimmwert CD 8 and Leuchte9FL RB2-Dimmwert CD 9 from "0" to "127". This works exactly as I had hoped.
    After testing all possible combinations of headlights, indicators, parking lights etc I did not notice any problems with my change.
    Is this kind of what you were going to suggest?
    Cheers mate,
    Lex.
    Golf MkVII 132TSI Alltrack MY16
    Polo GTI Mk6 MY19
  2. #1292
    Quote Originally Posted by Bladevsneo View Post
    Hi Don,
    Cheers mate,
    Lex.
    Lex: Great initiative - well done!! That's exactly what I would have suggested! By placing the DRL function in the "CD" alpha-pair, you have given DRL function the highest priority when there is a conflict. But since the DRL function can't conflict with the Parking light function (they are antithetical), you shouldn't have a problem.
  3. #1293
    Jul 2014
    The Hills, Sydney
    Has anyone coded Traffic Jam Assist into a 7.5 with DAP? Is it possible? Im looking at buying a 7.5 with DAP and keen to know if it can be done.
    2018 Golf 7.5 110TSi Comfortline | Drivers Assistance Package | Retrofitted: Traffic Jam Assist | Emergency Assist II | Light Assist | OEM Vienna Leather Sports Seats with full Highline Interior | Power Folding Mirrors
  4. #1294
    point: There has been a bunch of discussions over on the new Tiggy and the Passat B8 forum. Lot of folk hoping that it's just a coding question . My personal guess (and it's just that - a hunch) is that TJA is what's called SWAP (Software as Product) which means that it needs an activation number from the dealer that is tied to your VIN (assuming that the firmware in the module is up to date). Probably also needs a code-string tweak too (I suspect from what colleagues are saying on the other forums).
  5. #1295
    Sep 2017
    Bucharest, Romania
    Hi,
    I don't know if this has been discussed before. I have a Golf mk7 Trendline (2016) and for the last week or so I've been trying to install the Multifunction Steering wheel and get it fully working.
    So far:
    -the CAN Gateway has been switched from low to high, so right now I have a fully working Gateway High (no CP).
    -The multifunction steering wheel is installed and controls are mostly working (multifunction display - it's a trendline so it's the low version, + media controls).
    -The 'extra' cruise control wire is installed (ECU pin 56 - steering wheel controls pin 5 if I remember correctly)
    I have issues however with activating cruise control. Both cruise control and the speed limiter have been activated via VCDS in Engine and Steering, but when at least one of these two is activated, I get an error in Engine:
    "Check Coding of ECUs on Powertrain Data Bus"
    and when Cruise Control is activated, an error also appears in ABS as well.
    Cruise Control shows "ERR" on the display, but the speed limiter works just fine apparently. So the best guess right now would be that some sort of coding needs to be done on ABS side as well in order to prepare for CC. And for the Golf MK7 at least in VCDS for ABS, there's no helper, and there are 60 bytes to code...
    I've seen successful retrofits with instructions for cruise control via the signal stalker, but not on the multifunction steering wheel so far, and it would be a shame to just leave those controls there with no function. Can anyone help me with the missing coding?
  6. #1296
    Jul 2015
    Thanks for pointing me in the right direction mate! Cheers.
    Polo GTI Mk6 MY19
  7. #1297
    Jul 2014
    The Hills, Sydney
    This makes perfect sense, it may be the same as voice control activation, that said a Slovenian coding shop has enabled it on a Skoda Kodiaq...
    YouTube
  8. #1298
    Quote Originally Posted by point View Post
    YouTube
    Point: I looked at your video - I'm not sure that the video says that the coding shop actually activated TJA - it only shows what happens when TJA is activated.
    But then my Sovenian language skills aren't that good -in fact they are non existent !
  9. #1299
    Jul 2014
    The Hills, Sydney
    I thought so toon but translating the corresponding Facebook post on their page says that theyre the first to activate TJA and it's listed on their website - so theres definitely hope that it can be done!
  10. #1300
    Aug 2017
    Switzerland
    This comes from the Polo 6C, it might also work on the Golf 7, feel free to try.
    Auto light based on the light sensor in the cluster
    - VCDS Select module 09
    - Security access and fill in the code
    - Change the following adaptation channels
    Movie:
    YouTube
    [Left DRL]
    Leuchte4TFL LB43-Dimming_AB_4 100
    -Leuchte4TFL LB43-Dimming_CD_4 100
    Leuchte4TFL LB43-Dimming_Direction_CD_4 maximize
    Leuchte4TFL LB43-Dimming_Direction_EF_4 minimize
    Leuchte4TFL LB43-Dimming_EF_4 0
    Leuchte4TFL LB43-Dimming_GH_4 100
    Leuchte4TFL LB43-Light_Function_A_4 Interior light
    Leuchte4TFL LB43-Light_Function_B_4 Blinken links aktiv
    Leuchte4TFL LB43-Light_Function_C_4 Daytime running lights
    Leuchte4TFL LB43-Light_Function_D_4 Abblendlicht links
    Leuchte4TFL LB43-Light_Function_E_4 Terminal 58xt dimmer
    [Right DRL]
    Leuchte5 TFL RB6-Dimming_AB_5 100
    Leuchte5 TFL RB6-Dimming_CD_5 100
    Leuchte5 TFL RB6-Dimming_Direction_CD_5 maximize
    Leuchte5 TFL RB6-Dimming_Direction_EF_5 minimize
    Leuchte5 TFL RB6-Dimming_EF_5 0
    Leuchte5 TFL RB6-Dimming_GH_5 100
    Leuchte5 TFL RB6-Light_Control_HD_AB_5 Always
    Leuchte5 TFL RB6-Light_Function_A_5 Interior light
    Leuchte5 TFL RB6-Light_Function_B_5 Blinken rechts aktiv
    Light_Function_C_5 Daytime running lights
    Light_Function_D_5 Abblendlicht rechts
    Light_Function_E_5 Terminal 58xt dimmer
    I didn't figure this one out myself nor have I tested it since I don't have an MQB car.
    LB43 and RB6 are probably different on the Golf 7 too, but the terminal 58xt idea might work.
