Originally Posted by
Bladevsneo
Regarding how make the dot LED DRL to work along with U LED DRL in all light switch positions...
Is anyone able to reply? Is there any way to have just the dot LED running? Don, you are the lighting guru.... any suggestions?
Bladevsneo: Alas there are a number of ways that the dot can be wired on different headlight versions of the mk7. Have you made an admap of the BCM on your car yet?
And can you explain more clearly what you want the dot to do - are you saying that you want this lamp(s) to be switched-on by the ignition key and to remain switched on until the key is removed?
