Has anyone spotted a setting to change the resolution of the HVAC temperature control? I think the 0.5 degree stepping is silly and want to change one degree at a time.
Mk 7 R Wagon Wolfsburg. APR Stage 1. Removable towbar.
Am replying on my quote.
Will using this way help.? Just select channel 19?
Ross-Tech: VCDS Tour: Controller Channels Map
Samuel: Yes, the method in the video (affectionately known as an "admap") will be OK, but it will give you about 1,800-ish adaptation channels and their settings. You really should have a complete database of admaps from all the modules in your car saved somewhere as a reference source for when the brown stuff and the fan collide during a tweak (it's a matter of "when", not "if" something goes wrong with a tweak).
But perhaps a simpler way is to just take a screenshot of the Leutche-set values (you probably will need a couple of pictures for the full set)
Hardy: I've had a good look at the adaptation channels and the software switches in the code-string for the Auto HVAC module @ address hex08, but alas there doesn't appear to be anything remotely related to "integer-ising" the temp controller.
Happy to be told otherwise, but my suspicion is that this facility is embedded in firmware, which is a part of the module that is not accessible with VCDS (or OBD11). You could try a VCP cable, but you will need to have a fairly intimate understanding of the firmware code.
Hi, is there a summary page of the hyperlinks to the individual tweaks that people have listed? I've been trawling through this thread, but I may have missed it. Thanks.
bigtallbloke: perhaps look HERE
