Does it look like I'm out of luck?
GOLF GTI MY11 ADIDAS Candy White, Sunroof
GOLF GTI 40th ED, White with Sunroof
Bassik- I never like to give-up without a solution, but I'm running out of options.
I'm trying to understand why this problem has arisen on your car? The fact that the default value for Byte 24 was set is unusual for a mk7 that came factory fitted without VC. Plus, I consider myself to be fairly active in the mk7 forums and your problem is relatively unique. What's the history of the car?
PS: Long shot - but try resetting to factory settings through the MENU option
Honestly couldn't tell you the history. It's the 40th Years ED and was bought only 2 weeks ago. I got the OBDeleven straight away. Could it be that it's the 40th?
If I have the option to activate with a code from VW does that mean that I have the VC installed but just not activated, thus meaning I do have it installed from factory.
I like your determination because from reading on several forums I can confirm owners do in fact have the VC functioning as a mute button.
Don,
Could this be due to the fact that MIB 1 (what you and I have) behaves different to MIB2?
I can't remember how I came to this conclusion (whether it was the loaner VW gave me that has MIB2, or through reading forum posts), but I had the impression that MIB2 voice control button didn't function as a mute button like it did with MIB1?
Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
Hi all,
Has anyone success on removing the speed limit for Mirrorlink function on MIB2? I'm not quite sure how to tackle it... all helps are much appreciated.
