Page 116 of 198 FirstFirst ... 1666106114115116117118126166 ... LastLast
Results 1,151 to 1,160 of 1974
  1. #1151
    Apr 2012
    Bassik: OK - so I suspect I've responding under a misapprehension. If you DON'T have VC, then the tweak will already be implemented!!
    PS: Here's the escutcheon plate buttons
    Hmmm yeah that's what I thought. My MK6 doesn't have VC but the button acts as a pause button. But on my Mk7 It only displays a message on my MID requesting I need a code to activate VC.
    So is it broken or is it just how the mk7 works and relates to the CAN bus is configured?
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
  2. #1152
    Quote Originally Posted by Bassik View Post
    Bassik: Before VC was installed in my car, the button functioned as a mute facility (without any message appearing on the MFD when pressed). That's how I believe that it's meant to operate. If this isn't happening on your car, then perhaps there's another problem - maybe.
    What is the status of Byte 24, Bit 1 on your 5F module (SDS function)?
  3. #1153
    Apr 2012
    haha...can I still do this with OBDEleven as I don't have exactly VCDS. I'll have to check and see what it is... think I can?
  4. #1154
    Bassik: Of course you can use OBD11 - see below (scroll down to the very end of the screen after you select coding on the 5 F Module)
    If you can't get to my screenshot - simply post-up the code string for the 5F module, and I will calculate the Byte/Bit value
  5. #1155
    Apr 2012
    Sweet i'll take a look tomorrow... and let ya know.
    Cheers for helpin mate!
  6. #1156
    Jan 2012
    Just s quick question regarding this voice control. I have the button and it mutes and pauses, when asking vw if I can have VC installed they said no, is this correct?
    2015 Golf R. Lapiz Blue.
  7. #1157
    Quote Originally Posted by Reedy View Post
    Reedy: Hi. My understanding is that the default status of mk7's sold in Australia is for them NOT to have VC activated -your observation that the button "mutes and pauses" strongly supports this.
    Retrofitted VC is what's called "SWAP" (Software as Product) - so it needs an activation code that is tailored to your car's VIN (AFAIK)
    As I said in my Vortex post, I managed to get VC installed by VW at no additional cost after I purchased my car - it took a long time and much negotiation (read "argument") with the "Customer (don't) Care" staff @ VW Aust, but eventually they agreed. However, I consider the exercise to be a waste-of-time, because I don't believe that I have used VC more than a few times in the 3 x years that I have had the vehicle - it's an interesting novelty, but I certainly wouldn't pay money to have VC installed (IMO). I think from memory that it was around $400 to get the dealer to install VC - outrageous!!
  8. #1158
    Apr 2012
    VCDS (VAG-COM) codes and programmable options for Golf Mk7
    Hey Don. For the life of me can't get to this screen your showing?
    Where do I go?
    I've select central electronics and then coding but everything's in German. Even tho it's in English for the settings. I can't see any bytes for anything.
  9. #1159
    Apr 2012
    Ok found it and it was set to activated.
    Then set it to not activated.
    Did nothing.
  10. #1160
    Did nothing.
    Basik: OK, that's why you were getting the error message to install the activation code - because the 5F module was told that VC was installed (via the code-string setting), but the activation code wasn't entered - makes sense now!
    Strange that you still don't have mute after deactivating the Byte/Bit - have you tried resetting the MIBB unit after the change ? It's done like this:
    With the MIB unit turned-on press down the ON/OFF knob until the MIB unit switches-off AND keep holding the ON/OFF knob down until the unit turns-on again (about 10 seconds).
    Then try the VC button(s) again
