Korwin: OK - I'm half-way there (I think). I can explain the problem for the two outer tails (I think). The problem is that for North American Region (NAR) vehicles, the outer tails are also used for turn signals (American cars with incandescent lamps don't normally have the separate orange lamps that are used here), So the ESC instructions turn off the channels for the blinker function. However, our RoW (Rest of World) cars use some of these same channels to do other stuff (like the parking light, or what you call "running lights")
Here's what I suggest you do for the two outer tail lights
So - only change the
Lasttyp channel on each of the lamps in the table above - ignore ECS's other instructions (I think)
Now- the inner tail lights has me bamboozled (a bit) because I don't know how the adapter harness works. As I said before, NAR cars, don't have separate turn signal lamps, so my guess is that the harness generates this signal from what used-to-be the old inner tail light (I guess). The changes that are in the ECS instructions suggest this, but I'm reading the Leuchte programming instruction "between-the-lines". If my guess is correct. then I would implement the ECS instructions for the two inner tails (I think).
So now we come to your error messages whenever you switch-on the blinkers. Again, this is a guess, but if my hunch about the inner tails providing the turn signal function to your new fittings is correct - then it begs the question of what happened to the old wires that used to supply the rear incandescent orange turn signals (which NAR cars don't have)? If these are not used anymore and if the allied Leuchte-sets are still active, then the BCM will think that the incandescent filament is blown on both lamps - hence your error message (I think)
If my hunch is correct, you will need to shut-down the two Leuchte-sets for the old orange turn signal lamps as follows:
- (1)-Leuchte18BLK HLA60-Lasttyp 18 - change to not active ( default is 12 - Blinkleuchten)
- (1)-Leuchte19BLK HRC31-Lasttyp 19 - change to not active ( default is 12 - Blinkleuchten)
