Page 111 of 198 FirstFirst ... 1161101109110111112113121161 ... LastLast
Results 1,101 to 1,110 of 1974
  1. #1101
    Feb 2017
    Turkey
    HELP Messed up VCDS Coding Fuel Consumption Way Off
    I was fiddling around with my friend's MK VII Golf and I messed up the instrumentation coding. Now the fuel consumption gauge is behaving strangely. It keeps getting higher when coasting in neutral instead of dropping, and gets lower when pushing the accelerator! It's like reversed. But I didn't do anything related to fuel consumption in long coding and adaptation. I reversed some coding I've done but it didn't help. And I have lost the autoscan file Can you help me please? What should I look for?
  2. #1102
    Quote Originally Posted by Juzam View Post
    Juzam: Hello and welcome to the forum.
    Wow, I have never heard of those symptoms - I would like to know how you did that (it's an interesting effect)!
    Whilst you may have lost your autoscan file (how did you do that?), I'm hoping that you still have your CodingLog.CSV and ApdLog.CSV files. Just look in the Ross-Tech/Debug directory on the laptop that you used to make the changes. As the names imply each of the files will contain a record of the code-string and adaptation channel changes. The records contain both the before and after values - just revert to the original settings
  3. #1103
    Jul 2015
    Quote Originally Posted by MRG_AU View Post
    Good morning,
    I found the way to make the dot LED DRL to work along with U LED DRL in all light switch positions finally. extra affect Instrument cluster illuminated all the time with stock phototransistor X1..X5 values.
    1. Select 09 - Central Electr control module
    2. Select Security Access - 16 from the "Open Controller" screen
    3. Enter the magic number 31347 and return to the "Open Controller" screen
    4. Select Adaptation - 10 from the "Open Controller" screen
    5. From the pull-down button Select (6)-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht, is not active by default, make this active. (Google translation result is Daytime running light daytime running lights additionally activated parking light)
    More observation:
    • Instrument Cluster Illumination, I have not yet checked whether the intensity of illumination changes based on the light with this Mod. (ICI coming on is no magic here, I believe it will be illuminated if light switch is moved to parking lights day or night. since the parking lights are forced to run along with DRL's cluster stays on). Don's work on this as per Post#446 is exquisite. This mod keeps the Dot LED on in all light switch positions.
    • I checked deactivate start stop function value and it showed mode not active. But I am 100% sure I saved the value “stop prohibition, no start request”. So when I saved and tested it without restarting the car it worked. But when I switch off the car overnight and started in the morning it has gone back to mode not started, maybe or maybe I did not save it properly (no way), that is why start stop started working again. At least this is my belief so I have reverted back minimum voltage stock value for start stop and set the deactivate start stop back to “stop prohibition, no start request” for further observation.
    Concern:
    I am not sure if this Dot LED is capable of running all the time. Do they have enough cooling heat sinks? Could someone kindly advise on this matter, please.
    I tried this on my 2016 Golf Alltrack and it worked ok but the downside is the tail lights are also on at all times with the Dot LED. Has anyone else found this?
    Golf MkVII 132TSI Alltrack MY16
    Polo GTI Mk6 MY19
  4. #1104
    Jan 2017
    Poland
    Hallo everyone. i have question. Is it possible to make extra screen on fis without installing special box like polar fis advanced ? VCDS (VAG-COM) codes and programmable options for Golf Mk7-screenshot_20170305-153341-jpg
  5. #1105
    Quote Originally Posted by Piotr W View Post
    Piotr W: I don't believe that it is possible - in fact, I'd fairly certain that even POLAR FIS won't do it on a mk7 (it only fits a mk5 and mk6)
    Incidentally, you only just beat my speed!!
  6. #1106
    Jan 2017
    Poland
    Hallo Don. That is the screen shot of YouTube film. Here is link to original film:
    https://www.youtube.com/watch?v=S1TuEy-ZT_s&t=406s
    Officially I don't drive so fast ( in my country You can drive maximum 140km/h on freeway)
    I even don't know how fast my car can go. I ride a second hand GTI poorly equiped - that why I'm looking for upgrades over here.
    I bought OBD11 PRO. I made many changes allready. Few days ago I saw MK7 with two "U" leds on in each front light. I thought I can turn that option in my car too but looks like it's not possible. Is it really possible only in R lights?
    Don Istill have problem with my radio. Text info for radio stations doesn't work. Radio goes off when I turn key to 0 position in ignition. Can You give me some tips what adaptations shoud I change to change those problems? How to check my radio type? I mean is it MIB1 oraz MIB2? Whats the difference? I have only 3 languages in my radio - is it possible to upgrade it? Most of VW in Europe have many many more languages in radio.
    Best regards Piotr
  7. #1107
    Feb 2016
    The product is called MFA XP Lite - and here is the PDF
    http://www.mfa-xp.de/mfaxp_lite_v2_datenblatt_B00.pdf
    Last page has the pricing and screen shot
  8. #1108
    Jan 2017
    Poland
    Quote Originally Posted by anonymous View Post
    Hallo.Thank You for information.
    Best regards Piotr
  9. #1109
    Jan 2017
    Çorlu
    👍 you are great 👍
    Samsung'tan gönderildi...
  10. #1110
    Ciao Don after installing the rain / light sensor (8U0 955 559 B) I would like to activate the feature, however, did not automatically closed in case of rain in my BCM voice can select the Bit 2 in Byte 0, could you tell me how to activate any further voice to be able to close the windows automatically?
    I'll put screenshot of my VCDS.
    Setting in my infotainment.
    Your photo of the setting found on the web.
    VCDS (VAG-COM) codes and programmable options for Golf Mk7-n533glo-png
    I should also delay ignition car lights could you tell me the coding to be done via VCDS?
