Page 110 of 198 FirstFirst ... 1060100108109110111112120160 ... LastLast
Results 1,091 to 1,100 of 1974
  1. #1091
    Hello Don Thanks for the always fast response, mine is a Composition Media Mib 2 color monitors Golf My 2016VCDS (VAG-COM) codes and programmable options for Golf Mk7-20170213_071605-jpg
  2. #1092
    UPDATE v.1.5
    Dossier Modificaciones OBDEleven, ODIS, VAGCOM & VCP VW Golf MKVII
    Some News in v.1.5 :
    LINK - > PDF DOSSIERS TWEAKS FOR VW GOLF MKVII
    https://goo.gl/D37qgp
    Version v.1.5 10-02-2017
    Size + 176MB
    Number of pages 300
    For the next version 1.6 will be included the complete codification and verified!
    I leave you a present!
    AreaView 360º 3D en Golf 2014 con Mib2
    Amazing!
    Incorporation of another Retrofit's in PDF
    Inversor 12v to 110v/230v 150w original Golf 7 Variant
    This modification is valid for All generations of Golf , MQB (Leon , Passat, Skoda,...)...
    LINK - > PDF Brico Inversor 12v to 110v/230v 150w original for VW Golf MKVII / MQB
    http://goo.gl/D5q8oo
    Version v.1.0 16-12-2016
    Size + 14MB
    Number of pages 16
    Brico Media In Discover PRO1 for VW Golf MKVII
    ENLACE - > PDF Brico Media In en Discover PRO1 para VW Golf MKVII
    https://goo.gl/3tPNUS
    Version v.1.0 10-10-2016
    Size + 14MB
    Number of pages 13
    http://www.clubvwgolf.com/foro/
    http://www.clubvwgolf.com/foro/showt...-dudas/page126
    Enjoy it!!
    Regards!!
    XaGiCo
  3. #1093
  4. #1094
    Quote Originally Posted by fabbromix View Post
    Fabbromix: Hmm................ there's your problem (I suspect)!
    earlier his year, I spent a considerable time helping a colleague on the Vortex forum who had tried to implement this tweak on a Discover Media unit which is better optioned that your Composition Media (albeit his was MIB1, not MIB11).
    My Vortex colleague (who I won't name) also tried to implement this tweak, but as he was using OBD11 dongle, he used the long coding feature to select Skin 2 in the Byte17_Skinning entry for Information Control Unit 1 - which is the translation for this tweak in OBD11 speak. And his problems started with this mistake!
    The code-string change was accepted by the 5F module, but after he reset the MIB unit (by holding down the ON/OFF knob), he was unable to access any of the operational screens in the MIB unit. What happened was that he could hear the radio through the speakers, but the MIB screen wouldn't go past the opening screen (the VW emblem that appears at start-up).
    Not only that, but he was unable to access the control module again to revert the setting to their original value (he was using an OBD11 dongle)
    Anyhow after a few attempts we were finally able to solve the problem (mainly by clearing the App cache on his tablet and resetting the module via OBD11), but it was a salutary lesson that CAUTION should always be exercised when applying tweak instructions to equipement that wan't intended by the author. I'm not blaming XaGiCo, but whilst his instructions are well done, pictures and the Spanish language can only go so far in explaining the limitations of the tweaks - I certainly mean no offense to XaGiCo's excellent work!
    So - what I think will happen if you force this code into the 5F module is that you will attempt to apply a skin for which there is no software in the module's firmware. After you reset the MIB, the software will go though the normal start-up routine and it will try to load the non-existent skin - result, the screen won't go post the VW emblem albeit the non-display functions on the MIB will probably still work (as observed by my Vortex colleague)!!
    My advice (for what it's worth) is to not pursue this tweak with your current MIB unit!!
  5. #1095
    Ok Don!! Thank You!!! Vero Amico Ciaoooo
    I would buy a OBDeleven which normal version or PRO tips me, I have not the faintest idea of differences between the two and how to use it.
  6. #1096
    If you Want to modify anything (i.e. Apply one or more tweaks) you need to buy the Pro version, as The standard version does not allow to make any modification.
    In italian : se vuoi usarlo per fare modifiche devi comprare per forza la versione Pro: la versione standard non consente di fare modifiche, solo leggere valori e usare le apps
    ciao!
  7. #1097
    Quote Originally Posted by halfmillion View Post
    ciao!
    Halfmillion: Hi - Whilst I don't disagree with your recommendation, Here's the official information regarding the difference between the two dongle versions
    OBDeleven
    • Automatic vehicle identification from VIN (Vehicle identification number)
    • Read and clear diagnostic trouble codes from all control units that is installed in your car (i.e. Engine, Transmission, ABS, Airbag, Multimedia, Air conditioning, etc.)
    • Diagnostic trouble codes in 7 languages: English, German, Russian, Polish, French, Spanish, Italian
    • Read information about control unit (i.e. Part number, Software number, Coding, etc.)
    • Diagnostic data log sharing via email
    • Battery status
    • Connected cars history
    • Gauges
    • Engine, Equipment and Fault code lookups
    • DIY manuals
    OBDeleven Pro
    • All of the above
    • Home screen PRO theme (more info in main screen: engine code, battery voltage, faulty control units list)
    • Programming (coding, long coding, adaptation)
    • Basic settings
    • Output tests
    • Live data
    • Car programming history
    • One touch Apps for quick module programming
    So it really depends on the intended use - but the real decision variable between the two versions is the cost differential for those in the EU (I assume that there is still an EU and that Italy is still a member of the organisation )
    OBDeleven = 35.99 Euro
    OBDeleven Pro = 54.99 Euro
  8. #1098
    (...cut...)
    Hi Don! Thanks for all valuable feedback, information, tweaks, DYI and knowledge you are constantly providing!
    I fully confirm detailed differences as reported by you (I do own an OBD11), and also pricing (it takes 2-4 weeks for delivery). In a nutshell, I just wanted to let fabbromix know that PRO version is needed for any tweak (including VIM i.e. Video in motion, Which was the main reason for me to buy obd11 for my Skoda Octavia Scout 4x4 184cv dsg with Columbus!)
  9. #1099
    Feb 2017
    spain
    Angry
    gelocatil: here you go- from my mk7 which works as described in my previous post
    (1)-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung
    (2)-Driving light and parking light-Schlusslicht mit Bremslichtfunktion not active
    (3)-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus active
    (4)-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided
    (5)-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active
    (6)-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren not active
    (7)-Driving light and parking light-Warnung Fahrt mit Standlicht not active
    ( 8 )-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min
    (9)-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active
    (10)-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig
    (11)-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren
    (12)-Driving light and parking light-Allwetterlicht Einschaltgrenze 0 km/h
    (13)-Driving light and parking light-Allwetterlicht Ausschaltgrenze 0 km/h
    (14)-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h
    First of all thanks for answer.
    Well i tried changing the 3 adaptations and nothing changed, or so i think...
    uploaded a video with the behaviour, i dont know if kessy can affect in any way. other thing annoying me is the license plate lamp, also stays lighted when turn off the engine !!
    Can be this related with the "single side parking lights" or similar?
    another adaptation finded now im my couch that can fit my problem is some related "after-run"wow sounds great..
    After-run for park light:
    Bedingungen zur Beendigung des Standlichtnachlaufs:
    abschalten nach der Nachlaufzeit
    Standlicht-Nachlaufzeit:
    30.0 min
    other backups found shows "inactive" while mine "active"
    Ah, the backup done with obd11 if you want to take a look.
    https://drive.google.com/open?id=0Bz...XNnQlZmYnE2anc
    i think must look a mk7 near me and made a backup to transfer to my car and look what happen...
    car info. 2.0TDI 150 CRBC my14 extras:ACC,DLA,sunroof,keyless and rear LED retrofitted
    greets!!
  10. #1100
    Jan 2017
    UK, North West England
    Mark: I'm mortified and very sorry - my only excuse for the obvious error in my advice is a rapidly deteriorating membrane (from old age) and an overfondness of single malt scotch.
    But thank you for your kindness in not pointing-out that I'd forgotten one of the fundamental laws of Leuchte programming: ALWAYS, always consider the matter of priority from the inevitable conflicts whenever Leuchte-sets have more than one lighting function!!
    Anyhow, I've re-designed the tweak the way that it should have been when I first responded to your request! As I said above, the trick is to give the parking light function the highest priority so that it takes precedence whenever the turn signal operates coincident with the parking light.
    Again my apology - it's back to remedial Leuchte programming school for me!!
    PS: I intend to re-write my initial response (the correct way) so as not to confuse others who might read the post in the future - hope this doesn't cause you any problems
    Hi Don,
    Sorry for the delay in getting back to you.
    I have implemented the changes as detailed and can happily confirm that everything is working as expected/wanted.
    Please don't worry about any issues caused, I really appreciate the help and learning from all the information that you provide!
    Thanks again
    Mark
    Drive: Golf GTI 5DR Manual (Non PP) Build Week 48, Delivered 29/12/2016, Pure White, 18" Austin Alloys, Dynaudio, Car-Net App and Voice Control
