Poitr: Dont be impressed - there's much about the mk7 of which I am ignorant and the more I understand, the more my ignorance becomes apparent!
Hope that your OBD11 dongle arrives soon, but before you start making changes, I suggest that you make a FULL database of the "virgin" adaptation channel settings and long-coding values. Regardless of what type of diagnostic device that you intend to use, the existence of fulsome records of the original control module variables will be an invaluable tool when the brown stuff and the fan meet - which will happen at some stage in your learning proccess
I wrote a badly worded paper on how to do this for VCDS (see the VCDS reference thread on this forum), but it's a little different with an OBD11 dongle. Instead, I've attempted to capture the essence of the procedures in the series of screen-shots below. Make sure that you repeat the process for ALL the control modules in your car.
hmm.......... I don't know! But it must be able to be changed with coding/adaptation channels because our mk7s in Australia operate in the manner that you describe - the MMI in our cars turn-off when the key is removed (i.e. the "S switch" is opened).
My suspicion, and it's a pure guess is that the answer may be found in the green engineering menu in the MIB, but I've not spent much time in this part of the control module, so I'm not sure.
Perhaps someone else here has the answer?
PS: Here's a video of how to access the green engineering screen using OBD11 - have a look, but take care when changing settings -please
OK ..... that's real odd. In Aussie mk7s (mine at least), when the rotary switch is on Auto position, the parking lights (both front and rear tails) turned off whenever the key is removed from the ignition lock (i.e. when the "S switch" in the ignition lock-barrel is open).
I'm guessing, but try this: Go to the BCM (@address hex09), enter the magic number 31374 and search for an adaptation channel titled
(3)-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus. Change the setting to active and see what happens
gelocatil: here you go- from my mk7 which works as described in my previous post
(1)-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung (2)-Driving light and parking light-Schlusslicht mit Bremslichtfunktion not active (3)-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus active (4)-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided (5)-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active (6)-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren not active (7)-Driving light and parking light-Warnung Fahrt mit Standlicht not active ( 8 )-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min (9)-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active (10)-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig (11)-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren (12)-Driving light and parking light-Allwetterlicht Einschaltgrenze 0 km/h
(13)-Driving light and parking light-Allwetterlicht Ausschaltgrenze 0 km/h (14)-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h
Hallo.
Today my OBD11 finally arrived to me. After installation and connecting obd11 and android phone I've logged in.
And it apeared that:
"If this changed was made, it should have enabled the rear-fog light symbol in the instrument panel when the rotart light switch is pulled out twice - as below" - it wasn't done. After I changed it rear fog light apeares on intrument cluster after pulling twice rotary switch.
But I found other problem - when I pull rotary switch once both front and rear fog lights are on. So something else is wrong.I don't know yet if it's from wrong coding (which we made before ) or from connections in harnes. I need to solve that problem.
Second thing that I changed with obd11 is that now I can check refuel quanity.
Tommorow I'll try to do backup files for each modules.
Regards Piotr
Hi Don,
Tonight I noticed an issue with the coding.
When indicating with the rear lights on, the inner red lamps are also blinking at the normal rear light brightness. For some reason I must have not noticed this was happening when I applied the coding, as it was during the day I must not have checked every light switch position possible!
I have removed the Blinken command from E27 & F27, so now no issues when indicating with the rear lights on. Of course when activating the hazard lights the inner reds luminance to 100%.
Any other suggestions on how to enable without causing issues when indicating?
Thanks again for all your coding help and support on this and other sites, much appreciated.
Mark
Drive: Golf GTI 5DR Manual (Non PP) Build Week 48, Delivered 29/12/2016, Pure White, 18" Austin Alloys, Dynaudio, Car-Net App and Voice Control
Mark: I'm mortified and very sorry - my only excuse for the obvious error in my advice is a rapidly deteriorating membrane (from old age) and an overfondness of single malt scotch.
But thank you for your kindness in not pointing-out that I'd forgotten one of the fundamental laws of Leuchte programming: ALWAYS, always consider the matter of priority from the inevitable conflicts whenever Leuchte-sets have more than one lighting function!!
Anyhow, I've re-designed the tweak the way that it should have been when I first responded to your request! As I said above, the trick is to give the parking light function the highest priority so that it takes precedence whenever the turn signal operates coincident with the parking light.
Again my apology - it's back to remedial Leuchte programming school for me!!
PS: I intend to re-write my initial response (the correct way) so as not to confuse others who might read the post in the future - hope this doesn't cause you any problems
Hello Don I tried editing posted by our friend XaGiCo to transform the screen of my Composition Media 6.5 "in Carbon version but unfortunately I can not find the item you select in order to make the change (I'll put screenshot).
Do you have any other resource in your hat magic to give us to be able to operate the screen carbon style?
