is it possible to set the "CAR" page of the infotainment screen to always begin in the 'SINCE START' page (i.e., not in the vehicle status page) ??
Jimmyjames: OK "Golf Variant" works for me - it looks like this:
Kind-of looks like the "station wagon" on your first post. If you check the Codinglog.CSV file that lives in the Ross-Tech/Debug directory on the laptop that you used to make changes, you should see a record of when the change to the code-string was made to the car. Just look for records that have Address 5F in the first column.
Anyway, try changing the value of these Bytes to 027300 - as per my screenshot
Awesome thanks for that. I think I worked out what I did. I used the long coding helper to deactivate the safety warning.
I think as I was arrowing down through the bytes I must have inadvertently scrolled through the drop downs to select the Variant in the first byte. Anyway I copied the original coding from the log and then changed the 2 to a 0 to disable the warning again. Voila, I have a GTI hatch again on the screen. Cheers!
My Vehicle status only shows up first when there is a message such as door open or fuel needed, otherwise what comes up first is what I last left it on.
2015 Golf R. Lapiz Blue.
Try this:
Before you power on the car, close all your car doors first. It should just go to the last page.
Door open, low fuel, service reminder or any other warning will hijack your screen.
I agree tho, it's nice that it tells me my door is open, but it should return to the original screen once I have closed my door, and there are no other statuses to show...
Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
